UVM_RAL Frontdoor write & write_reg
Thanks a lot it worked for me.
I assigned this handle in reg_seq and it worked fine.
apb_rb.ld_reg.read(status,value,.parent(this));
But when i’m use this read method simulation gets hang only for read not for write operation and I found that the problem is in my monitor(forever loop). and I didn’t understood one thing is that it is not coming out from the loop, is there any problem in the predictor monitor connection. if you could help me from this it will be really helpful, Here is my monitor logic
class master_monitor extends uvm_monitor;
`uvm_component_utils(master_monitor)
//transaction handle
master_trans mon_txn
uvm_analysis_port #(master_trans) monport;
//constructor
//build_phase
mon_txn = master_trans::type_id::create("mon_txn");
//run_phase
task master_monitor::run_phase(uvm_phase phase);
forever begin
if(vif.apb_monitor_cb.penable) begin
@(vif.apb_monitor_cb);
mon_txn.paddr= vif.apb_monitor_cb.paddr;
mon_txn.pwdata= vif.apb_monitor_cb.pwdata;
monport.write(mon_txn);
