Q1) iam still a beginner at UVM, i want to know why we are using the raise objection?
does it related to the run_phase of the components as all the run phases run in parallel , so the objection mechanism make them like run in Series?
and i saw 2 ways of raising objections some putting the raise objection inside the sequence class and some putting it inside the test class what is the difference between these ways?
Q2) also i have read that when we call raise objection we set a count to 1 and this count have to increase when we use raise objection again.
the above sentence will help me when iam using alot of raising objection in my test bench right ?
Thanks.
