I want to print an item which contains header fields and raw data in this format:
name type size value
field1 type size value
field2 type size value
field3 type size value
data-byte-0 data-byte-1 … data-byte-15
data-byte-16 data-byte-17 … data-byte-31
So, I implemented do_print() in this manner:
function void some_obj::do_print(uvm_printer printer);
string data_string;
data_string = {data_string, "\n--------------------------------------------------\n"};
foreach(m_arr[ii]) begin
if((ii != 0) && ((ii % 16) == 0)) begin
data_string = {data_string, "\n"};
data_string = {data_string, $sformatf("%02x ", m_arr[ii])};
printer.print_int("m_hdr_f_1", m_hdr_f_1, $bits(m_hdr_f_1));
printer.print_int("m_hdr_f_2", m_hdr_f_2, $bits(m_hdr_f_2));
printer.print_int("m_hdr_f_3", m_hdr_f_3, $bits(m_hdr_f_3));
printer.print_string("m_arr", data_string);
endfunction : do_print
But this causes some weird side effects.
- If data is big, then so are the number of spaces after each header field.
- If data is big, then so are the number of dashes in the delimiter that the UVM printer adds.
Looking at the code of the table printer I understand that this is because my data string is counted as a single string that is very long.
What can I do to avoid this issue?
I thought about extending the table printer and overriding calculate_max_widths() but it is not virtual.
