Hello ,
when i try to run my uvm env and try to override the monitor via override monitor then override occurs but null pointer error for port occurs, can u pls suggest,
for m_monitor.aport.connect(agent_aport);` line
UVM_INFO classes_v/axi_scoreboard.sv(24) @ 0: uvm_test_top.m_env.m_axi_scoreboard [SCOREBOARD] BUILD
xmsim: *E,TRNULLID: NULL pointer dereference.
File: /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_port_base.svh, line = 463, pos = 38
Scope: worklib.uvm_pkg::uvm_port_base#(uvm_pkg::uvm_tlm_if_base#(T,T))::connect
Time: 0 FS + 13
Verilog Stack Trace:
0: function worklib.uvm_pkg::uvm_port_base#(uvm_pkg::uvm_tlm_if_base#(T,T))::connect at /pkg/cadence-xcelium-/21.02.001/i686-linux/tools/methodology/UVM/CDNS-1.1d/sv/src/base/uvm_port_base.svh:463
1: function worklib.$unit_0x746ee0b2::axi_agent@2763_4.connect_phase at ./classes_v/axi_agent.sv:42
2: function worklib.uvm_pkg::uvm_connect_phase@685_2.exec_func at /pkg/cadence-xcelium-/21.02.001/i686
Please help:
monitor.sv
ifndef AXI_MONITOR define AXI_MONITOR
class axi_monitor extends uvm_monitor;
`uvm_component_utils(axi_monitor)
uvm_analysis_port #(stimulus) monitor_aport;
virtual axi_intf intf;
stimulus m_seq;
// Constructor
super.new(name,parent);
extern virtual function void build_phase(uvm_phase phase);
extern task run_phase(uvm_phase phase);
extern task collect_data(stimulus m_seq);
endclass:axi_monitor
function void axi_monitor::build_phase(uvm_phase phase);
if(!uvm_config_db#(virtual axi_intf )::get(this,“”,“intf”,intf))
`uvm_error(" ERROR MONITOR",$sformatf("%s ",this.get_type_name()))
monitor_aport = new(“monitor_aport”, this);
task axi_monitor::run_phase(uvm_phase phase);
@(posedge intf.reset);
m_seq = stimulus::type_id::create(“m_seq”,this);
collect_data(m_seq);
task axi_monitor::collect_data(stimulus m_seq);
forever
@(posedge intf.clk);
m_seq.data = 32’h12345678;
`uvm_info(“MONITOR”,$sformatf(“MONITOR %h”,m_seq.data),UVM_LOW);
monitor_aport.write(m_seq);
`endif
ovveride_monitor.sv
class override_monitor extends axi_monitor;
`uvm_component_utils(override_monitor)
uvm_analysis_port #(stimulus) aport;
stimulus m_seq;
// Constructor
function new(string name=override_monitor", uvm_component parent);
endclass:override_monitor
function void override_monitor::build_phase(uvm_phase phase);
uvm_error(" ERROR MONITOR",$sformatf("%s ",this.get_type_name())) uvm_info(“OVERRIDE MONITOR BUILD”,“”,UVM_LOW);
aport = new(“aport”, this);
`uvm_info(“OVERRIDE MONITOR BUILD”,$sformatf(“override monitor %s”,this.sprint()),UVM_LOW)
task override_monitor::run_phase(uvm_phase phase);
task override_monitor::collect_data(stimulus m_seq);
forever
`uvm_info(“override MONITOR”,$sformatf(“MONITOR %h”,m_seq.data),UVM_LOW);
aport.write(m_seq);
agent.sv
ifndef AXI_AGENT_PKG define AXI_AGENT_PKG
class axi_agent extends uvm_agent;
`uvm_component_utils(axi_agent)
axi_sequencer m_seqr ;
axi_driver m_driver;
axi_monitor m_monitor;
//axi_config m_config;
uvm_analysis_port #(stimulus) agent_aport;
function new(string name,uvm_component parent);
extern virtual function void connect_phase(uvm_phase phase);
endclass: axi_agent
function void axi_agent::build_phase(uvm_phase phase);
if(!uvm_config_db# (virtual axi_intf)::get(this,“”,“intf”,intf))
`uvm_error(“ERROR AGENT”,“BUILD_PHASE”)
agent_aport = new("agent_aport", this);
m_seqr = axi_sequencer::type_id::create(“m_seqr”,this);
m_driver = axi_driver::type_id::create(“m_driver”,this);
//m_driver.intf = intf;
m_monitor = axi_monitor::type_id::create(“m_monitor”,this);
`uvm_info(“UMONITOR”,get_type_name(),UVM_LOW);
function void axi_agent::connect_phase(uvm_phase phase);
m_driver.seq_item_port.connect(m_seqr.seq_item_export);
`endif
