I have seen some places’ build phase is declared as virtual and some places non-virtual. what’s the difference between both of them and which one is recommended in what scenario?
ex:
why in the build phase it is important to call super.build_phase.
In SystemVerilog, once a method gets declared as
virtual in a base class, it remains virtual in all derived classes. The
virtual keyword becomes optional. I suggest always being explicit and using it.
If you use the `uvm_field_* automation macros in a uvm_component, some functionality will not work unless you call super.build_phase(). We recommend against using the field automation macros.
Hi Dave
Can you please explain why you suggest always declare the phases as virtual?
As I understand, adding virtual to a phase method in my class is exactly the same as without the virtual.
