Uvm package compilation error
hi
when i compile ubus example it is not showing error, when i compile my environment it is showing this error
Error-[SE] Syntax error
“/VCS_MX_2011.03/etc/uvm-1.0/src/dpi/uvm_dpi.cc”, 28: token is ‘#’
#define VCS
can anyone help me out of this…
You are passing DPI-c code to SV compiler. VCS as a script around the executable(s) tries to figure out internaly, but at times gets confused. Show your command line. Typically in VCS you can use UVM with:
vcs -ntb_opts uvm
that should take care of it.
HTH
Ajeetha, CVC
Hi
Even I have got similar error.
Am stuck with package compilation error. here is the error i was getting while compiling,
QuestaSim vlog 10.0a Compiler 2011.02 Feb 21 2011
– Compiling package uvm_pkg
– Compiling package pci_package
– Importing package uvm_pkg
** Error: pci_package.sv(27): near “endpackage”: syntax error, unexpected endpackage, expecting function or task
make: *** [comp] Error 2
please anyone can help me in resolving this error.
Thanks in advance.
In reply to rameshsedam:
Without seeing your pci_package.sv, it will be difficult to diagnose the problem.
-Tom
