Hi All,
I have very strange requirement, where i have following base class.
class base_monitor extends uvm_monitor;
   virtual function xyz_operation();
    // Logic 1 is performed
   endfunction : xyz_operation
Now, due to certain extra requirement i have to override base_monitor with following extended_monitor.
class extended_monitor extends base_monitor;
    // Logic 2 is performed
Now, for verification of most of scenarios, i have to use xyz_operation() method of extended_monitor, as base_monitor doesn’t have such support and i can not remove base_monitor from hierarchy. so, i performed overriding of base_monitor with extended_monitor.
But for verification of some additional features, i have to use xyz_operation() method of extended_monitor initially, then have to use xyz_operation() method of base for some time(Corruption of data path), and then back to xyz_operation() method of extended at the end in single seed simulation. as extended_monitor doesn’t have support for such feature. and i don’t want to change any code in extended_monitor or base_monitor.
So, question is simple, Does uvm provides any support to remove/add overriding of components run time? can anyone please suggest the appropriate scenario to overcome this?
Thanks and Regards,
Mitesh Patel
