UVM:: new task basd phases:: excution order
Hi.
In the early version of UVM, The excution order is new(),build(),connect()…run()…
and the RUN phase is bottom-up. In UVM1.1, there are some new task based phases are added : pre_reset, reset, post-reset … pre_main, main, post_main …
I would like to confirm :
1. can i assume those new phases are some sub phases of run phase?
2. excution order is: build, connect, end_of_elaboration, start_of_simulation, pre_reset, reset, post_reset, pre_conf, conf, post_conf, pre_main, main, post_main… ?
3. in the component hierachy, the same phase are also excuted bottom-up.
I have tried to set_config a enviroment variable in the body of a seq, and the seq is started from run_phase in my uvm_test. By putting get_config in post_main phase of my uvm_env, it works :
UVM_INFO /p/com/eda/synopsys/vcsmx/E-2011.03-SP1-2-B-1/etc/uvm-1.1/base/uvm_resource_db.svh(130) @ 0: reporter [CFGDB/SET] Configuration ‘*.vari’ (type int) set by = (int) 3
UVM_INFO test.sv(24) @ 0: env_ [env_] i am env post_main_phase
UVM_INFO /p/com/eda/synopsys/vcsmx/E-2011.03-SP1-2-B-1/etc/uvm-1.1/base/uvm_resource_db.svh(130) @ 0: reporter [CFGDB/GET] Configuration ‘env_.vari’ (type int) read by env_ = (int) 3
but if changing post_main_phase() in my env to run_phase(), it wont work. is it correct behavir?
thanks
andrew
The new UVM run time phases (pre-reset, reset etc) execute in parallel to the run phase in order to provide compatability with the OVM. They are not sub-phases of the run phase.
The execution order you have listed looks correct.
You should now see why your set/get configs are not working. Provided the set occurs before the get, things should work, regardless of the phasing system. What you need to do is organise the execution flow so that set occurs before get.
See http://verificationacademy.com/uvm-ovm/Phasing/Overview for more details.
