Uvm_hdl_read() works only with STD_LOGIC_VECTOR. (for INTEGER or ENUM (e.g. FSM), only 0 is returned, or a random INTEGER value
Hi
Using uvm_hdl_read()it only seems to work for STD_LOGIC_VECTOR. If the signal is an INTEGER or ENUM (e.g. FSM), only 0 is retured, or an implausible value with an integer signal…
Is this something wrong or does it just work only with STD_LOGIC_VECTOR?
Vlad
Perfectly true. This is the svh agent:
hdl_status = uvm_hdl_read(“hdl_top.DUT.abc_fsm_inst.state_r”, hdl_data);
hdl_status = uvm_hdl_read(“hdl_top.DUT.abc__fsm_inst.state_stdv_s”, hdl_data);
hdl_status = uvm_hdl_read(“hdl_top.DUT.abc_fsm_inst.shift_cnt_r”, hdl_data);
hdl_status = uvm_hdl_read(“hdl_top.DUT.abc_fsm_inst.shift_cnt_stdv_s”, hdl_data);
vhdl signals & conversion
SIGNAL sck_cnt_r :INTEGER RANGE 0 TO (2**cfg_sclk_div_cnt_i’LENGTH) := 1;
SIGNAL sck_cnt_stdv_s :STD_LOGIC_VECTOR(cfg_sclk_div_cnt_i’LENGTH-1 DOWNTO 0);
SIGNAL shift_cnt_r :INTEGER RANGE 0 TO ADC_DATA_BW_C := 0;
SIGNAL shift_cnt_stdv_s:STD_LOGIC_VECTOR(INTEGER(CEIL(LOG2(REAL(ADC_DATA_BW_C))))-1 DOWNTO 0);
state_stdv_s <= state2stdv(state_r);
shift_cnt_stdv_s <= STD_LOGIC_VECTOR(TO_UNSIGNED(shift_cnt_r,shift_cnt_stdv_s’LENGTH));
sck_cnt_stdv_s <= STD_LOGIC_VECTOR(TO_UNSIGNED(sck_cnt_r,sck_cnt_stdv_s’LENGTH));
Questa output
UVM_INFO D:/…[READ HDL PATH shift_cnt]] shift_cnt_r: 0x00000000 - Status: 1 - shift_cnt_stdv_r: 0x00000000 - Status: 1
UVM_INFO D:/… [READ HDL PATH state]] state_r: 0x00000000 - Status: 1 - state_stdv_s: 0x00000000 - Status: 1
Please advise.
In reply to vlad_velea:
I’d use a bind contruct to connect to the VHDL world. The bind connects a SV module and you can use uvm_hdl_read() without any limitation.
The instantiation of the VHDL DUT is tool generated inside SV i.e.:
DUT(
.sys_clk_i(uvm_abc_bus.sys_clk),
.reset_n_i(reset_n),
.avs_address_i(avs_address),
.avs_write_i(avs_write),
.avs_writedata_i(avs_writedata),
.avs_read_i(avs_read),
.avs_readdata_o(avs_readdata),
Where exactly to use bind?
Vlad
You are observing DUT internal signals, Right. You can connect to any internal signal using the SV bind construct.
