UVM_FATAL: reporter [TTINST] An uvm_test_top already exists via a previous call to run_test
Hello All,
I’m a newbie to UVM. What I’m trying to do is to have a simple UVM environment set up for my DUT. I’ve followed the standard guideline, such as creating a agent (sequencer + driver -driving the DUT), and a simple testcase.
However, when I call run_test() from the initial block of my top_tb (by using +UVM_TESTNAME=testcase), I always got the UVM_FATAL reported as:
UVM_FATAL @ 0: reporter [TTINST] An uvm_test_top already exists via a previous call to run_test
I’m wondering what the cause for the UVM_FATAL is?
Thanks in advance for your help.
Tam Nguyen
You either called run_test() twice in the same simulation, or you’ve explicitly created a component called “uvm_test_top”, neither of which is allowed.
Thanks for the reply.
I found the cause for this issue - that was due to the way I used asim command.
