Hi, I am getting this error in the code below. Can anybody help me resolve this error?
Error-[SE] Syntax error
“/root/Downloads/Soc-DV/dv/uvm_agents/jtag_agent/jtag_driver.sv”, 39: token
is ‘logic’
logic [4:0] data;
System verilog keyword ‘logic’ is not expected to be used in this context.
task drv_action(input jtag_sequence_item seq_item );
jtag_if.wait_clks(9);
jtag_if.wait_clks_neg(1);
logic [4:0] data;
case (seq_item.action)
JTAG_SEQ_ITEM_ACTION_SYNC_RESET: begin
data = 5'h1f;
//`uvm_info(get_name(), "Synchronous Reset", UVM_NONE)
//logic [4:0] data;
for (int i=0; i<$size(data); i++ ) begin
jtag_if.TMS <= data[i];
JTAG_SEQ_ITEM_ACTION_SHIFT_IR: begin
`uvm_info(get_name(), "shift-IR", UVM_NONE)
endcase
`uvm_info(get_name(), "reset sequence has been sent to the interface", UVM_NONE)
