In reply to Prawin kumar:
I had a deeper look to your code. You do not understand the UVM build process using the different phases: build_phase, connect_phase.
Passing the virtual interface through your environment is a nightmare. TLM components never have a virtual interface!
Watch the UVM related videos in the Verification Academy, then clean-up and run your code.
