UVM_ERROR
In reply to Prawin kumar:
The agent will create its own driver, monitor and sequencer. There is no need to create them in the environment. The agent should also have an analysis port, which is connected to the monitor’s analysis port. You will connect the agent’s analysis port to the scoreboard.
A poorly written agent won’t have an analysis port, in which case you will connect the monitor’s analysis port to the scoreboard.
