In reply to Shivakumar AN:
Hi shiva,
I made it shiva but in driver am getting error again .
ERROR: uvm_test_top.env.driver [ac_lpc_driver] No virtual interface specified for this driver instance
Thanks,
Hi shiva,
Thanks,
In reply to Prawin kumar:
Can you try after changing
uvm_config_db#(virtual ac_lpc_if)::set( this, “env”, “vif”, vif);
to
uvm_config_db#(virtual ac_lpc_if)::set( this, “*”, “vif”, vif);
Giving * will make sure all the below hierarchy components can get from higher hierarchy.
Thanks,
Shivakumar
Hi,
before error in ‘test’ hierarchy
Now at ‘env’.
ERROR; uvm_test_top.env [ac_lpc_env] No virtual interface specified for this env instance.
Hi,
Why this error is occurred?
ac_lpc_tx_seq test_seq;
phase.raise_objection(this, “starting test_seq”)
test_seq = ac_lpc_tx_seq::type_id::create(“test_seq”,this);
test_seq.start(env.agent.sequencer);
#100;
phase.drop_objection(this, “finished test_seq”);
endtask: run_phase
ERROR:“Incompatible types at assignment: .test_seq<ac_lpc_tx_seq>create(”“test_seq”“,this,”“”“)<uvm_sequence_item>.”"
Thanks,
Looks a Little bit strange, because you never mentioned ‘test_seqcreate’.
My guess is your code does not look like this:
Hi,
That is create method right,for test_seq.for rise and drop objection for sequence.
even though am getting error
E:“Incompatible types at assignment: .test_seq<ac_lpc_tx_seq> ← create(”“test_seq”“,this,”“”“)<uvm_sequence_item>.”
Is the sequence compatible with the sequencer? It looks like it is not. Does the sequence generate the same seq_items as the sequencer is parameterized?
Could you please provide the code for your test_seq and the corresponding sequencer.
class ac_lpc_sequencer extends uvm_sequencer#(sequence_item);
`uvm_component_utils(ac_lpc_sequencer)
function new(string name,uvm_component parent);
super.new(name,parent);
endclass:ac_lpc_sequencer
class ac_lpc_tx_seq extends uvm_sequence#(sequence_item);
sequence_item req;
function new(string name = “ac_lpc_tx_seq”);
super.new(name);
task body;
req = sequence_item::type_id::create(“req”);
for(int i=0;i<10;i++) begin
start_item(req);
assert (req.randomize());
finish_item(req);
`uvm_info(“AC_LPC_TX_SEQ_BODY”, $sformatf(“Transmitted frame %0d”, i), UVM_LOW);
endtask: body
endclass:ac_lpc_tx_seq
This looks OK.
But I found something else in the buil_phase of your env:
env = ac_lpc_env::type_id::create("env", this);
//test_seq = ac_lpc_tx_seq::type_id::create("test_seq",this);
sequencer = ac_lpc_sequencer::type_id::create("test_seq",this); //this wrong
sequencer = ac_lpc_sequencer::type_id::create("sequencer",this); // this is correct!
if(!uvm_config_db#(virtual ac_lpc_if)::get(this, "", "vif", vif)) begin
`uvm_fatal("ac_lpc_test", "No virtual interface specified for this test instance")
uvm_config_db#(virtual ac_lpc_if)::set( this, "env", "vif", vif);
Hi,
Above code is wrong, because of in my ‘env’ i made the connections of scoreboard only, so no need to create ‘sequencer’ ok.
agent = ac_lpc_agent::type_id::create(“agent”,this);
scoreboard =ac_lpc_scoreboard::type_id::create(“scoreboard”,this);
driver =ac_lpc_driver::type_id::create(“driver”,this);
monitor =ac_lpc_monitor::type_id::create(“monitor”,this);
//sequencer =ac_lpc_sequencer::type_id::create(“sequencer”,this);
if (!uvm_config_db#(virtual ac_lpc_if)::get(this, "", "vif", vif)) begin
`uvm_fatal("ac_lpc_env", "No virtual interface specified for this env instance")
uvm_config_db#(virtual ac_lpc_if)::set( this, "agent", "vif", vif);
driver.drv_to_sb.connect(scoreboard.input_fifo.analysis_export);
monitor.item_collected_port.connect(scoreboard.output_fifo.analysis_export);
endclass: ac_lpc_env
Why are you creating a driver and monitor (and sequencer?) in your environment? You are creating an agent which should contain these components. In your environment, you should only create the agent and scoreboard.
In reply to cgales:
Because am made connections of driver to scoreboard and monitor to scoreboard in environment only. that’s why am creating agent components in environment also …
we cannot connect components without create right.
The agent will create its own driver, monitor and sequencer. There is no need to create them in the environment. The agent should also have an analysis port, which is connected to the monitor’s analysis port. You will connect the agent’s analysis port to the scoreboard.
A poorly written agent won’t have an analysis port, in which case you will connect the monitor’s analysis port to the scoreboard.
Hi,
What is verbosity of UVM_INFO in uvm monitor.
i.e deference between UVM_LOW,UVM_HIGH,UVM_NONE,UVM_MEDIUM.
Thanks,
This is what the Refernce Manual says:
Defines standard verbosity levels for reports.
UVM_NONE Report is always printed. Verbosity level setting can not disable it.
UVM_LOW Report is issued if configured verbosity is set to UVM_LOW or above.
UVM_MEDIUM Report is issued if configured verbosity is set to UVM_MEDIUM or above.
UVM_HIGH Report is issued if configured verbosity is set to UVM_HIGH or above.
UVM_FULL Report is issued if configured verbosity is set to UVM_FULL or above.
You should learn fo work with this Refermce Manual and the UVM Cookbook.
This comes with the UVM Class Library
http://www.accellera.org/downloads/standards/uvm
