UVM Driver Communication: get_next_item()/item_done() vs get()/put() — Which is Preferred in Industry?
In UVM, which driver communication style is more commonly used in industry and why?
  1. get_next_item() + item_done()
  2. get() + put()
I created simple examples of both methods and the behavior looks almost the same from the sequence side (start_item()/finish_item() flow).
The main difference I observed is:
  • With get_next_item()/item_done(), the sequence can use wait_for_item_done().
  • With get()/put(), there seems to be no need for wait_for_item_done() because the response comes through put()get_response().
Am I understanding this correctly?
What are the practical advantages, use cases, and industry reasons for choosing one method over the other?
get_next_item()/item_done() can be only used for on-piplined protocols.
get()/put() can be used for pipelined and non-pipelined protocols.
I think you meant “non-pipelined protocols”.
Basically it means only one transfer is active at a time between the sequence ↔ driver.
Michael, of cause.
I had a great teacher :wink:
I have a doubt about the initial driver-sequence communication. Does the driver send a request to the sequencer for a sequence item, or does the driver simply wait until a sequence item becomes available in the sequencer’s request FIFO?
