I am writing a UVM to test CDC FIFO, I have used read and write drivers to run independent read/write requests from the virtual sequence.
The first simple test I am doing is to do random read/write multiple times.
The virtual sequence body code:
virtual task body();
assert(randomize(m_times) with {m_times < FIFO_DEPTH;} );
wr_seq = cdc_fifo_write_seq::type_id::create ("wr_seq");
rd_seq = cdc_fifo_read_seq::type_id::create ("rd_seq");
repeat (m_times) begin
wr_seq.start(p_sequencer.m_wr_seqr);
rd_seq.start(p_sequencer.m_rd_seqr);
join
The read and write drivers sequence code (each has its own sequence):
`uvm_do (req)
The transaction type is shared between both drivers and its contain data member only.
The read driver run_phase code:
task drive_read();
transaction = new("transaction");
wait(vif.reset_n == 0);
vif.data_rd_en <= 1'b0;
wait(vif.reset_n == 1);
@(posedge vif.clk_rd);
forever begin
seq_item_port.get_next_item(transaction);
// #1ns
while (vif.empty) begin
vif.data_rd_en <= 1'b1;
seq_item_port.item_done();
`uvm_info("FIFO read DRIVER", "Running run_phase", UVM_HIGH)
drive_read();
The error I am getting in simulation is that after the first write, it is followed by a read. This asserts EMPTY signal and the read_driver should not assert read_enable for a second read to avoid underflow.
However, the ENABLE signal seems to be delayed a bit because it combinational circuit (some delta cycles I guess), so the condition while (vif.empty) is skipped causing underflow.
If I added like #1ns delay before this condition it works fine, but how I can solve this issue in a different way? is there is something wrong in the driver code or sequences?
Many thanks
