hello,
my qstns are: 1)what is uvm_do_with.how it works.
my understanding is:
uvm_do_with(seqncr,{seqncr.seq_item = values}
uvm do with sends the seqitem value assigned to sequencer,is it so?
2) what are virtual sequences.if we write data thru vsequencer and testcase..which one will be overwrtitten?
uvm_do_with belongs to the family of the uvm_do macros and is used in the body method of a sequence. It defines how the seq_items will be generated. `uvm_do_with allows to add constraints to the generation. The body method is executed by the sequencer and provides seq_items which can be retrieved by the uvm_driver using get or get_next_item.
