Hello Everyone,
Using uvm-connect to communicate between SystemC and SystemVerilog using generic payload.
UVM-SV agent generates a b_transport call for SC model, SC updates the gp and returning in SV world the contents are printed with correct value proceeding ‘x’ while response empty as “”.
Transaction send by SV world to SC: Sending to SC by SV
UVM_INFO tlm2sv_adapter.svh(171) @ 8565.000000 ns --: uvm_test_top.m_env.m_tlm2sv_adapter [tlm2sv_adapter] T3 Init send to Model
Name Type Size Value
t3_i uvm_tlm_generic_payload - @23529
address integral 64 'h0
command uvm_tlm_command_e 32 UVM_TLM_READ_COMMAND
response_status uvm_tlm_response_status_e 32 UVM_TLM_INCOMPLETE_RESPONSE
streaming_width integral 32 'h0
data darray(byte) 4 -
[0] byte 8 'h00
[1] byte 8 'h01
[2] byte 8 'h02
[3] byte 8 'h03
extensions aa(obj,obj) 0 -
Transaction updated by SC and printed in SC:
SYSTEMC TLM PRINTER@0.000008565
COMMAND: TLM_READ_COMMAND
ADDRESS: 0x0
LENGTH: 04
STREAMING_WIDTH: 00
RESPONSE: TLM_OK_RESPONSE
DATA[0]: 0x00
DATA[1]: 0x01
DATA[2]: 0x02
DATA[3]: 0x03
Transaction updated by SC and printed in SV: Returned by SC to SV
UVM_INFO tlm2sv_adapter.svh(173) @ 8565.000000 ns --: uvm_test_top.m_env.m_tlm2sv_adapter [tlm2sv_adapter] T3 Init updated by Model
response_status uvm_tlm_response_status_e 32 “”
[0] byte 8 'h00 x
[1] byte 8 'h01 x
[2] byte 8 'h02 x
[3] byte 8 'h03 x
UVM_INFO /sv/src/tlm2/uvm_tlm2_generic_payload.svh(499) @ 8565.010000 ns --: reporter@@t3_i [MISCMP] GP miscompare between ‘t3_i’ and ‘analysis_packet_tlm’:
lhs = UVM_TLM_READ_COMMAND [0x0000000000000000] = – – – – (status=UNKNOWN_RESPONSE)
rhs = UVM_TLM_READ_COMMAND [0x0000000000000000] = 00 01 02 03 (status=OK)
UVM_ERROR @ 8565.010000 ns --: uvm_test_top.m_env.m_scoreboard [ t3 TXN Comparator Mismatch] Model UVM_TLM_READ_COMMAND [0x0000000000000000] = – – – – (status=UNKNOWN_RESPONSE) does not match RTL UVM_TLM_READ_COMMAND [0x0000000000000000] = 00 01 02 03 (status=OK)
The scoreboard comparing both complains for mismatch of data and response.
Please help what this issue is all about.
Karandeep
