Can i get virtual interface directly to my Driver & Monitor Class from TB_TOP?
Or i need to get in test and after setting from test.
Raja Sekhar
Raja Sekhar
If your test is in a package, which it should be, then you can’t set it from the test. Packages cannot have hierarchical references to any instances of modules or interfaces. So you have to set it from TB_top or some other module instance.
Example:
TB_TOP:
interface if_h;
uvm_config_db#(virtual interface)::set(null,“*”,“vif”,if_h);
Driver:
virtual interface.drv_modport m_if_h
if(!uvm_config_db#(virtual interface)::get(this,“”,“vif”,m_if_h))
`uvm_fatal(“FATAL”,“You cannot get from Config_db Have you set Properly()?”)
In this example while getting the virtual interface i am getting the error like
ERROR:You cannot assign the interface if_h type to m_if_h.
Please give me the solution.
In reply to raja.kuraku:
How about a more complete example of what you are trying to do. I can only assume this is what you are trying to do
interface my_interface;
//... body
endinterface
module TB_TOP;
my_interface my_interface_inst();
my_DUT my_dut_inst(my_interface_inst);
uvm_config_db#(virtual my_interface)::set(null,"*","vif",my_interface_inst);
run_test();
Yes exactly i am setting the interface like as above example,
But when i am getting directly on my driver like i have shown in above example,
Then i am facing the problem of type of interface.
Driver should be
virtual my_interface.drv_modport m_if_h
if(!uvm_config_db#(virtual my_interface)::get(this,"","vif",m_if_h))
`uvm_fatal("FATAL","You cannot get from Config_db Have you set Properly()?")
I cannot see anything wrong in Raja’s code snippet. My doubt is whether instance name should be
same for both set and get methods.
Regards,
Chandan
In reply to chandanc9:
Yes Driver i have written like that only but it is showing that error.
Please give some possible mistakes and errors. For the above example.
And why i am not able to get?
Hi Raja,
You are setting only the interface into config_db from TB_TOP. I think if you are not setting the modport of the interface you cant get the same in your driver. Also your driver has m_if_h which is an instance of the modport of the interface and not the interface alone. Hence try changing the code in TB_TOP as:
uvm_config_db#(virtual interface.drv_modport)::set(null,“*”,“vif”,if_h);
Let us know if that works…
In reply to myashu:
Then We should set for each modport different.
By setting interface also we can get but here i am facing the problem like
Error for My Example Code:
** Error: (vsim-3978) ../env/m_agent/src/m_driver.sv(71): Illegal assignment to type ‘virtual interface’ from type ‘virtual interface.drv_modport’.
Sorry I didn’t asked the question properly.
Previously i was using this example.
EX-1:
TB_TOP:
interface vif;
uvm_config_db#(virtual vif)::set(null,“*”,“virtual_if”,vif);
Test:
uvm_config_db#(virtual vif)::get(this,“”,“virtual_if”,agnt_cfg.vif) //Because i have taken the interface handle in agent config class
uvm_config_db#(agnt_cfg)::set(this,“m_agent.*”,“agent_config”,agnt_cfg) // Setting the Agent config
Driver:
agent_config m_cfg_h;
virtual interface.drv_modport m_if_h;
uvm_config_db#(agnt_cfg)::get(this,“”,“agent_config”,m_cfg_h;)
Connect Phase: m_if_h = m_cfg_h.m_if_h;
But i want to get interface directly from top to my Driver class
EX-2:
TB_TOP:
interface vif;
Driver:
uvm_config_db#(virtual vif)::get(this,“”,“virtual_if”,m_if_h;)
When i am doing this i got the error like “You cannot assign the interface(Type mismatching)”.
I have done the same thing in the above example. But there is a handle in agent config through that i am assigning.
But When i am doing directly i am facing the problem.
From the answer of arun kumar i have got that, We cannot assign directly to the drv_modport, We need to get whole interface first after that by taking another handle we can assign the interface to the particular modport.
Am i correct or wrong please give me your Comments/Suggestions.
Thank you very much to all of you for spending your valuable time.
You code does not make any sense. Please use the code tags and show enough of your code that someone could compile it on their own.
Example:
TB_TOP:
interface if_h;
Driver:
virtual interface.drv_modport m_if_h // Need to be changed like virtual interface vif_0;
Hello Raja,
Change the declaration of virtual interface in driver class like virtual interface vif_0; and get the whole interface from the config_db and after getting whole interface you can get the modport access like vif_0.mp_if_1.signal1…(first modfort) vif_0.mp_if_2.signal2…(second modport)
Try it once it should work
