Uvm_config_db set method clarification
Hi everybody,
Just got a question on trying to figure out the interpretation of the set method I have in the code below I will be providing:
`include "uvm_macros.svh"
import uvm_pkg::*;
`include "ex_interface.sv"
`include "ex_test.sv"
`include "ex_design.sv"
module tb_top;
    bit clk, reset;
    always #5 clk = ~clk;
        reset = 1;
        #2
        reset = 0;
    // virtual interface
    adder_if vir_interface(clk, reset);
    // need the DUT
    adder DUT(.clk(vir_interface.clk), .reset(vir_interface.reset),
              .in1(vir_interface.input_1), .in2(vir_interface.input_2), .out(vir_interface.result));
        uvm_config_db#(virtual adder_if)::set(uvm_root::get(),"*","the_interface",vir_interface);
        run_test("the_test");
The part I need help in interpreting is the line of
Particularly, what does uvm_root::get() return? Is it the path of the root of hierarchy of the uvm components that I have laid out?
Sincerely,
Sangwoo
the “uvm_root” static get method returns a reference to the top-level “uvm_root” object which is base class in uvm bench
