Uvm_config_db set from sequence and get in tb_top
Is there any way to do uvm_config_db set from sequence and get in tb_top?
thanks & regards,
sanjoy
In reply to sanjay864u:
You can use uvm_root and get
Because a sequence is a transient object you might not know when to perform the get in the toplevel module.
