Hi All,
In below code, i’m setting an uvm_object in uvm_config_db after ranomizing it in base_test build_phase. And, in my_test, i created a child class of that object and override the constraints and then randomized in build phase. I got the same object in my virtual sequnece from uvm_config_db::get method. This object which i got in virtual sequece should have a randomized value with respect to my_test. But, it holds the base_test randomized value.
Could you please help me that, when i get the object from uvm_config_db::get method, it should hold the randomized value from my_test not from base_test.
Thanks in advance!!!
class object extends uvm_object;
`uvm_object_utils(object);
rand bit a;
rand bit b;
rand bit rand_en;
function object::new(string name ="");
super.new(name);
constraint a_cst{
a inside {0,1};
constraint b_cst{
b inside {0,1};
constraint ab_cst{
rand_en inside {0,1};
endclass : object
class base_test extends uvm_test;
`uvm_component_utils(base_test)
object ob;
extern function void build_phase(uvm_phase phase);
function base_test::new(string name, uvm_component parent);
super.new(name, parent);
function void base_test::build_phase(uvm_phase phase);
super.build_phase(phase);
ob = object::type_id::create("ob");
object.randomize with {rand_en == 0;};
uvm_config_db#(object)::set(null,"*","obj",this.ob);
class object_child extends object;
`uvm_object_utils(object_child);
constraint ab_cst {
rand_en inside {1};
function object_child::new(string name ="");
super.new(name);
endclass :object_child
class my_test extends base_test;
`uvm_component_utils(my_test)
object_child ob_ch;
endclass : my_test
function void my_test::build_phase(uvm_phase phase);
ob_ch = object_child::type_id::create(ob_ch);
ob_ch.randomize();
endfunction : build_phase
class seq extends uvm_sequence(uvm_sequence_item);
`uvm_object_utils(seq) // Register this sequence with the factory
`uvm_declare_p_sequencer(virtual_sequencer) // Get the handle of the virtual sequencer
bit tran;
bit addr;
extern virtual task body();
endclass : seq
task seq::body();
uvm_config_db#(object)::get(null,"*","obj",this.ob);
if(ob.rand_en != 0) begin
tran = a;
addr = b;
endtask: seq
Note : Please ignore any syntax errors. This is just a sample code.
