I set the following calue in the build of the test:
class tx_test extends test_base;
      super.build_phase(phase);
      uvm_config_db #(int) :: set (this, "*", "mem_int_min", 5);
      uvm_config_db #(int) :: set (this, "*", "mem_int_max", 12);
   endfunction: build_phase
endclass: tx_test
In the base_transaction class I want to get above values by:
class base_transaction extends uvm_sequence_item();
 function int my_randomize_int(int seed, int mem, string mem_name);
      int  max, min;
      string mem_name_max = {mem_name, "_max"};
      string mem_name_min = {mem_name, "_min"};
      uvm_config_db #(int)::get(null, "", "mem_int_max", max);
      uvm_config_db #(int)::get(null, "", "mem_int_min", min);
      // temp = $urandom_range(1,11);
      mem = ($urandom_range(max,min));
      //data_xi = temp1 - 1;
      if(mem != 0)
	return mem;
	return 0;
   endfunction: my_randomize_int
endclass: base_transaction
I don’t get the correct values (I got 0 instead).
