Uvm_config_db and dynamic array issue
Hey! I’m faced with problem i have class master_memory
class master_memory extends uvm_object;
    reg[7:0] memory_0[];
    reg[31:0] memory32_0[];
      `uvm_object_utils_begin(master_memory)
  function new(string name = "master_memory",uvm_component parent = null);
    super.new(name);
    memory_0 = new[20000];
    memory32_0 = new[5000];
  endfunction : new
I collect mem in monitor and trying to transfer it to scoreboard in extract_phase.
 virtual function void extract_phase(uvm_phase phase);
    super.extract_phase(phase);
      transfer_mem_to32bit();
      check_mem();
      uvm_config_db#(master_memory)::set(null, "*", "mm", mm);
In scoreboard I’m get this reference but all my array in master_memory class now uninit(read XX)
Where i lose array data?
virtual function void check_phase(uvm_phase phase);
    super.check_phase(phase);
      void'(uvm_config_db#(master_memory)::get(null, "*", "mm", mm));
      check_mem();
Thx for help!
In reply to favalligi:
Is it a problem with the array or any other simple class member variable? create one if it does not exist to test.
Make sure you are getting master_memory class object in scoreboard with assert/if condition. Currently you’re assigning output of get() method to void! May be you are using totally different object in SB.
In reply to mayurkubavat:
You should always use an if condition to check the status of a method call. Never use an assert statement as it can be disabled resulting in undesired behavior. Refer to this page for more information.
In reply to cgales:
Thanks but it wasn’t problem in this situation. Monitor was used by 2 agents but memory collected only in 1. When extract phase was invoked in 2nd agent its replace all data to uninit array.
