Hi ,
I’m running verification environment with SB.
added the uvm_comparer::compare_field_int to my env.
but got an error
who can help with this issue?
the size of bits that i compare is 36 bits, less then 64…
Thanks!
Hi ,
but got an error
Thanks!
@Brurya
Could you please provide the code of the class you are trying to compare it’s fields?
Not sure it is the reason for the failure.
Your class is not a parametric class, so you should not use:
`uvm_object_param_utils_begin
Just use instead the regular:
`uvm_object_utils_begin
Please try to fix it, and see if it solves the problem.
If it won’t help,
please provide next some code from:
…/env/sb/include/vrs_comprer.svh
I don’t think that is the reason for the failure. Please show us the line 95 of the comparer.
BTW, it would really help if you posted your code as formatted text, not as a picture.
These are the problematic lines:
94 function bit compare_field_int (string name,
95 logic[63:0] lhs,
96 logic[63:0] rhs,
97 int size,
98 uvm_radix_enum radix=UVM_NORADIX);
This function called from:
function bit compare_field (string name,
uvm_bitstream_t lhs,
uvm_bitstream_t rhs,
int size,
if(size <= 64)
return compare_field_int(name, lhs, rhs, size, radix);
The issue is resolved.
I run now with UVM-1.2,
so, I need to change the lines above from:
95 logic[63:0] lhs,
96 logic[63:0] rhs,
97 int size,
To:
uvm_integral_t lhs,
uvm_integral_t rhs,
int size,
Thanks all
