I was wondering whether it is possible to access a register/memory/register block. For example, if I could access it using a hierarchical path that’s concatenated and also an absolute path. For example, a register
Why would want to provide 2 ways to describe the path to the same register? A register only has a single hierarchical path. What are you trying to accomplish?
I want to have a backdoor that’s implemented without any concern for the actual DUT implementation. As in the hierarchy of my RAL/register model does not, but could, correspond to the actual hierarchy on the DUT. I know I can add the entire hierarchy to the hdl path slice, as long as it connects to the top of the testbench, but I want to avoid this because it could be prone to mistakes.
The following picture could be good example. It’s not a problem to give a hierarchical path for the regA (M4.fieldA) and regB (M5.fieldB), regC is inaccessible because it’s not below M3 and anything like (Module1.M2.fieldC) for the path slice will not work. Is there a way to get around this? Is there any additional documentation or tutorials besides the uvm cookbook from verification academy?
A register has a single instance path. Having multiple paths to a physical register does not make sense, unless you are using some quantum entanglement. That won’t be in SystemVerilog until 2033 at the earliest. :-)
You can define multiple backdoor paths for a register block, these will be stored in a queue internally. Backdoor methods like peek() and poke() will iterate through this queue and perform the operation with first matching path. In case none of the paths in queue matches, you will get an error.
