Uvm_analysis_imp_decl
can any one explain me the use of
`uvm_analysis_imp_decl
in order to use multiple exports in a class we must use this macro?
thanks
In reply to lalithjithan:
If you want each export to call a different write() method, you need to use these macros (or write the equivalent code yourself)
The UVM reference manual has a very good example of its use.
If export connects to an amayisis_fifo, then you do not need to use the macros because each fifo instance provides a write() implementation.
