Uvm analysis get method issue
I am not able get transaction from monitor and also compare function `uvm_info or err verbosities are also not printing.
I tried debugging in monitor and SB with info sprint statement, in monitor I am able to see the sampled transaction data from interface but where as in SB I am not able to see anything.
Help me regarding this issue.
/////////////------------------------Master_Monitor_Code---------------------------///////////////////////////
class axi_master_monitor extends uvm_monitor;
`uvm_component_utils(axi_master_monitor)
  virtual axi_interface.MR_MON axi_m_mon_vif;
  axi_master_trans axi_m_xtn_h;
  axi_master_agent_config axi_m_agnt_cfg;
  //int ie;
  uvm_analysis_port #(axi_master_trans) monitor_port;
  extern function new(string name="axi_master_monitor", uvm_component parent);
  extern function void build_phase(uvm_phase phase);
  extern function void end_of_elaboration_phase(uvm_phase phase);
  extern task run_phase(uvm_phase phase);
  extern task collect_data();
  extern task  write_data();
  extern task read_data();
  extern function void report_phase(uvm_phase phase);
function axi_master_monitor::new(string name="axi_master_monitor", uvm_component parent);
  super.new(name,parent);
		monitor_port=new("monitor_port",this);
function void axi_master_monitor::build_phase(uvm_phase phase);
  super.build_phase(phase);
  if(!uvm_config_db #(axi_master_agent_config)::get(this,"","axi_master_agent_config",axi_m_agnt_cfg))
  `uvm_fatal("MASTER_MONITOR","can not get() axi_m_agnt_cfg from uvm_config_db")
function void axi_master_monitor::end_of_elaboration_phase(uvm_phase phase);
  axi_m_mon_vif=axi_m_agnt_cfg.axi_m_agt_cfg_vif;
task axi_master_monitor::run_phase(uvm_phase phase);
      collect_data();
task axi_master_monitor::collect_data();
			forever
								if(axi_m_agnt_cfg.write_read_flag==2'b00)
															write_data();
								else if(axi_m_agnt_cfg.write_read_flag==2'b01)
														read_data();
								else if(axi_m_agnt_cfg.write_read_flag==2'b10)
														write_data();
                                              			read_data();
                                              join
task axi_master_monitor::write_data();
 	axi_m_xtn_h=axi_master_trans::type_id::create("axi_m_xtn_h",this);
	//write_address
	      @(axi_m_mon_vif.master_monitor)
     wait(axi_m_mon_vif.master_monitor.AWVALID && axi_m_mon_vif.master_monitor.AWREADY)
	axi_m_xtn_h.AWADDR=axi_m_mon_vif.master_monitor.AWADDR;
	axi_m_xtn_h.AWID=axi_m_mon_vif.master_monitor.AWID;
    axi_m_xtn_h.AWLEN=axi_m_mon_vif.master_monitor.AWLEN;
    axi_m_xtn_h.AWSIZE=axi_m_mon_vif.master_monitor.AWSIZE;
    axi_m_xtn_h.AWBURST=axi_m_mon_vif.master_monitor.AWBURST;
   `uvm_info(get_type_name(),$sformatf("axi_m_xtn_h.AWLEN=%d",axi_m_xtn_h.AWLEN),UVM_LOW);
	//write data
	  for(int i=0; i<=axi_m_xtn_h.AWLEN ;i++)
         wait(axi_m_mon_vif.master_monitor.WVALID && axi_m_mon_vif.master_monitor.WREADY)
		 axi_m_xtn_h.WID=axi_m_mon_vif.master_monitor.WID;
	   	axi_m_xtn_h.WDATA[i]=axi_m_mon_vif.master_monitor.WDATA;
	  // axi_m_xtn_h.WSTRB[i]=axi_m_mon_vif.master_monitor.WSTRB;
	//write response
			wait(axi_m_mon_vif.master_monitor.BREADY && axi_m_mon_vif.master_monitor.BVALID)
			axi_m_xtn_h.BID=axi_m_mon_vif.master_monitor.BID;
			axi_m_xtn_h.BRESP=axi_m_mon_vif.master_monitor.BRESP;
join
			`uvm_info("MASTER_MONITOR_WRITE_CHHANLE",$sformatf("printing from MASTER_MONITOR_WRITE_CHHANLE \n %s",axi_m_xtn_h.sprint()),UVM_LOW);
			 monitor_port.write(axi_m_xtn_h);
      axi_m_agnt_cfg.axi_mon_count_h++;
task axi_master_monitor::read_data();
	//read_address
  repeat(2)
  @(axi_m_mon_vif.master_monitor);
	 wait(axi_m_mon_vif.master_monitor.ARVALID && axi_m_mon_vif.master_monitor.ARREADY)
	axi_m_xtn_h.ARADDR=axi_m_mon_vif.master_monitor.ARADDR;
	axi_m_xtn_h.ARID=axi_m_mon_vif.master_monitor.ARID;
    axi_m_xtn_h.ARLEN=axi_m_mon_vif.master_monitor.ARLEN;
    axi_m_xtn_h.ARSIZE=axi_m_mon_vif.master_monitor.ARSIZE;
    axi_m_xtn_h.ARBURST=axi_m_mon_vif.master_monitor.ARBURST;
	//read data
	    for(int i=0; i<=axi_m_xtn_h.ARLEN ;i++)
      repeat(2)
        wait(axi_m_mon_vif.master_monitor.RREADY && axi_m_mon_vif.master_monitor.RVALID)
	    axi_m_xtn_h.RID=axi_m_mon_vif.master_monitor.RID;
	    axi_m_xtn_h.RDATA[i]=axi_m_mon_vif.master_monitor.RDATA;
      `uvm_info(get_type_name(),$sformatf("axi_m_xtn_h.RDATA[%0d]=%d",i,axi_m_xtn_h.RDATA[i]),UVM_LOW);
		axi_m_xtn_h.RRESP=axi_m_mon_vif.master_monitor.RRESP;
	    axi_m_xtn_h.RLAST=axi_m_mon_vif.master_monitor.RLAST;
`uvm_info("MASTER_MONITOR_READ_CHHANLE",$sformatf("printing from MASTER_MONITOR_READ_CHHANLE \n %s",axi_m_xtn_h.sprint()),UVM_LOW);
  function void axi_master_monitor::report_phase(uvm_phase phase);
    `uvm_info(get_type_name(), $sformatf("Report: Master_Monitor_Sent %0d transactions",axi_m_agnt_cfg.axi_mon_count_h),UVM_LOW);
/////////////////////////---------------Scoreboard-------------------------------------/////////////////////
class axi_SB extends uvm_scoreboard;
        `uvm_component_utils(axi_SB)
	//master analysis fifo
	uvm_tlm_analysis_fifo#(axi_master_trans)fifo_master;
  uvm_tlm_analysis_fifo#(axi_master_trans1)fifo_master1;
	//slave analysis fifo
	uvm_tlm_analysis_fifo#(axi_slave_trans)fifo_slave;
axi_env_config m_cfg;
		// xtns_compared : number of xtns compared
		// xtns_dropped : calculates number of xtns failed
        int  xtns_compared ,xtns_dropped;
        axi_master_trans xtn_master;
  		axi_master_trans1 xtn_master1;
		axi_slave_trans xtn_slave;
        extern function new(string name,uvm_component parent);
		 extern function void WADDR_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
		extern function void WDATA_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
		extern function void WRESP_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
		extern function void RADDR_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
		extern function void RDATA_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
function axi_SB::new(string name,uvm_component parent);
		fifo_master= new("fifo_master", this);
  		fifo_master1= new("fifo_master1", this);
		fifo_slave= new("fifo_slave", this);
	xtn_master=	axi_master_trans::type_id::create("xtn_master",this);
  	xtn_master1= axi_master_trans1::type_id::create("xtn_master1",this);
	xtn_slave=	axi_slave_trans::type_id::create("xtn_slave",this);
function void axi_SB::build_phase(uvm_phase phase);
        if(!uvm_config_db #(axi_env_config)::get(this,"","axi_env_config",m_cfg))
                `uvm_fatal("CONFIG","cannot get() m_cfg from uvm_config_db. Have you set() it?")
task axi_SB::run_phase(uvm_phase phase);
                forever
									if(m_cfg.write_read_flag==2'b00)
                                                      fifo_master.get(xtn_master);																											  fifo_master1.get(xtn_master1);
													  fifo_slave.get(xtn_slave);
													join
													WADDR_check_data(xtn_master,xtn_slave);
													WDATA_check_data(xtn_master,xtn_slave);
													WRESP_check_data(xtn_master,xtn_slave);
									else  if(m_cfg.write_read_flag==2'b01)
													join
													RADDR_check_data(xtn_master,xtn_slave);
													RDATA_check_data(xtn_master,xtn_slave);
									else if(m_cfg.write_read_flag==2'b10)
													join
function void axi_SB::WADDR_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
				if(xtn_master.AWADDR==xtn_slave.AWADDR)
                          $display("******************xtn_master.AWADDR=%0d**************xtn_slave.AWADDR=%0d",xtn_master.AWADDR,xtn_slave.AWADDR);
								`uvm_info("SCOREBOARD","COMPARISION for AWADDR is SUCCESSFUL",UVM_LOW)
									xtns_compared++ ;
								`uvm_error("SCOREBOARD","COMPARISION is MISSMATCH")
								xtns_dropped++ ;
				if(xtn_master.AWLEN==xtn_slave.AWLEN)
							`uvm_info("SCOREBOARD","COMPARISION for AWLEN is SUCCESSFUL",UVM_LOW)
								xtns_compared++ ;
								xtns_dropped++ ;
				if(xtn_master.AWSIZE==xtn_slave.AWSIZE)
								`uvm_info("SCOREBOARD","COMPARISION for AWSIZE is SUCCESSFUL",UVM_LOW)
								xtns_compared++ ;
								xtns_dropped++ ;
				if(xtn_master.AWBURST==xtn_slave.AWBURST)
								`uvm_info("SCOREBOARD","COMPARISION for AWBURST is SUCCESSFUL",UVM_LOW)
								xtns_compared++ ;
								xtns_dropped++ ;
				if(xtn_master.AWID==xtn_slave.AWID)
							`uvm_info("SCOREBOARD","COMPARISION for AWID is SUCCESSFUL",UVM_LOW)
							xtns_compared++ ;
								xtns_dropped++ ;
function void axi_SB::WDATA_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
				for(int i=0;i<=xtn_master.AWLEN;i++)
					        if(xtn_master.WID==xtn_slave.WID)
										`uvm_info("SCOREBOARD","COMPARISION for WID is SUCCESSFUL",UVM_LOW)
											xtns_compared++ ;
							if(xtn_master.WDATA[i]==xtn_slave.WDATA[i])
										`uvm_info("SCOREBOARD","COMPARISION for WDATA is SUCCESSFUL",UVM_LOW)
											xtns_compared++ ;
											`uvm_error("SCOREBOARD","COMPARISION of WDATA is MISSMATCH")//uvm_error
											xtns_dropped++ ;
function void axi_SB::WRESP_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
      if(xtn_master.BID==xtn_slave.BID)
         xtns_compared++ ;
      `uvm_error("SCOREBOARD","COMPARISION of WID is MISSMATCH")
       xtns_dropped++ ;
function void axi_SB::RADDR_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
					if(xtn_master.ARADDR==xtn_slave.ARADDR)
										$display("************ARADDDDDDDDDDDDDDDRRRRRRRR******%d**************%d",xtn_master.ARADDR,xtn_slave.ARADDR);
										`uvm_info("SCOREBOARD","COMPARISION for ARADDR is SUCCESSFUL",UVM_LOW)
										xtns_compared++ ;
					if(xtn_master.ARLEN==xtn_slave.ARLEN)
										`uvm_info("SCOREBOARD","COMPARISION for ARLEN is SUCCESSFUL",UVM_LOW)
										xtns_compared++ ;
					if(xtn_master.ARSIZE==xtn_slave.ARSIZE)
									xtns_compared++ ;
					if(xtn_master.ARBURST==xtn_slave.ARBURST)
										xtns_compared++ ;
					if(xtn_master.ARID==xtn_slave.ARID)
								xtns_compared++ ;
									xtns_dropped++ ;
function void axi_SB::RDATA_check_data(axi_master_trans xtn_master,axi_slave_trans xtn_slave);
					//for(int i=0;i<=xtn_master.ARLEN;i++)
						//begin
						        if(xtn_master.RID==xtn_slave.RID)
												`uvm_info("SCOREBOARD","COMPARISION for RID is SUCCESSFUL",UVM_LOW)
												xtns_compared++ ;
							/*	if(xtn_master.RDATA[i]==xtn_slave.RDATA[i])
												`uvm_info("SCOREBOARD","COMPARISION for RDATA is SUCCESSFUL",UVM_LOW)
												xtns_compared++ ;
										end*/
												`uvm_error("SCOREBOARD","COMPARISION of RDATA is MISSMATCH")
													xtns_dropped++ ;
						//end
function void axi_SB::report_phase(uvm_phase phase);
`uvm_info(get_type_name(), $sformatf("\n \n Number of Read Transactions Dropped : %0d \n Number of Read Transactions compared : %0d \n\n",xtns_dropped,xtns_compared), UVM_LOW)
//--------------------------Sim results------------------------------------------------------/////////////
# UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(215) @ 0: reporter [Questa UVM] QUESTA_UVM-1.2.3
# UVM_INFO verilog_src/questa_uvm_pkg-1.2/src/questa_uvm_pkg.sv(216) @ 0: reporter [Questa UVM]  questa_uvm::init(+struct)
# UVM_INFO @ 0: reporter [RNTST] Running test first_axi_test...
# UVM_INFO @ 0: reporter [UVMTOP] UVM testbench topology:
# Name                         Type                        Size  Value
# uvm_test_top                 first_axi_test              -     @476
#   axi_env_h                  axi_env                     -     @499
#     axi_sb_h[0]              axi_SB                      -     @649
#       fifo_master            uvm_tlm_analysis_fifo #(T)  -     @656
#         analysis_export      uvm_analysis_imp            -     @695
#         get_ap               uvm_analysis_port           -     @687
#         get_peek_export      uvm_get_peek_imp            -     @671
#         put_ap               uvm_analysis_port           -     @679
#         put_export           uvm_put_imp                 -     @663
#       fifo_master1           uvm_tlm_analysis_fifo #(T)  -     @703
#         analysis_export      uvm_analysis_imp            -     @742
#         get_ap               uvm_analysis_port           -     @734
#         get_peek_export      uvm_get_peek_imp            -     @718
#         put_ap               uvm_analysis_port           -     @726
#         put_export           uvm_put_imp                 -     @710
#       fifo_slave             uvm_tlm_analysis_fifo #(T)  -     @750
#         analysis_export      uvm_analysis_imp            -     @789
#         get_ap               uvm_analysis_port           -     @781
#         get_peek_export      uvm_get_peek_imp            -     @765
#         put_ap               uvm_analysis_port           -     @773
#         put_export           uvm_put_imp                 -     @757
#     axi_v_sequencer_h        axi_virtual_sequencer       -     @540
#       rsp_export             uvm_analysis_export         -     @547
#       seq_item_export        uvm_seq_item_pull_imp       -     @641
#       arbitration_queue      array                       0     -
#       lock_queue             array                       0     -
#       num_last_reqs          integral                    32    'd1
#       num_last_rsps          integral                    32    'd1
#     m_collector_h1[0]        master_collector1           -     @824
#       analysis_imp           uvm_analysis_imp            -     @831
#     m_collector_h[0]         master_collector            -     @809
#       analysis_imp           uvm_analysis_imp            -     @816
#     master_agt_top_h1[0]     axi_master_agt_top1         -     @522
#       axi_m_agnt_h           axi_master_agent1           -     @861
#         axi_m_drv_h          axi_master_driver1          -     @885
#           rsp_port           uvm_analysis_port           -     @900
#           seq_item_port      uvm_seq_item_pull_port      -     @892
#         axi_m_mon_h          axi_master_monitor1         -     @870
#           monitor_port       uvm_analysis_port           -     @877
#         axi_m_seqr_h         axi_master_sequencer1       -     @908
#           rsp_export         uvm_analysis_export         -     @915
#           seq_item_export    uvm_seq_item_pull_imp       -     @1009
#     master_agt_top_h[0]      axi_master_agt_top          -     @511
#       axi_m_agnt_h           axi_master_agent            -     @1024
#         axi_m_drv_h          axi_master_driver           -     @1048
#           rsp_port           uvm_analysis_port           -     @1063
#           seq_item_port      uvm_seq_item_pull_port      -     @1055
#         axi_m_mon_h          axi_master_monitor          -     @1033
#           monitor_port       uvm_analysis_port           -     @1040
#         axi_m_seqr_h         axi_master_sequencer        -     @1071
#           rsp_export         uvm_analysis_export         -     @1078
#           seq_item_export    uvm_seq_item_pull_imp       -     @1172
#     s_collector_h[0]         slave_collector             -     @839
#       analysis_imp           uvm_analysis_imp            -     @846
#     slave_agt_top_h[0]       axi_slave_agt_top           -     @533
#       axi_s_agt_t_h          axi_slave_agent             -     @1187
#         axi_s_drvh_h         axi_slave_driver            -     @1211
#           rsp_port           uvm_analysis_port           -     @1226
#           seq_item_port      uvm_seq_item_pull_port      -     @1218
#         axi_s_mon_h          axi_slave_monitor           -     @1196
#           monitor_port       uvm_analysis_port           -     @1203
#         axi_s_seqrh_h        axi_slave_sequencer         -     @1234
#           rsp_export         uvm_analysis_export         -     @1241
#           seq_item_export    uvm_seq_item_pull_imp       -     @1335
# master driver axi_m_agnt_cfg.write_read_flag=00
# master driver axi_m_agnt_cfg.write_read_flag=01
# UVM_INFO .\src\master_monitor1.2.sv(99) @ 30: uvm_test_top.axi_env_h.master_agt_top_h[0].axi_m_agnt_h.axi_m_mon_h [axi_master_monitor] axi_m_xtn_h.AWLEN= 1
# UVM_INFO .\src\slave_monitor.sv(111) @ 50: uvm_test_top.axi_env_h.slave_agt_top_h[0].axi_s_agt_t_h.axi_s_mon_h [axi_slave_monitor] axi_s_xtn_h.WDATA[0]=2295421533
# UVM_INFO .\src\slave_monitor.sv(111) @ 130: uvm_test_top.axi_env_h.slave_agt_top_h[0].axi_s_agt_t_h.axi_s_mon_h [axi_slave_monitor] axi_s_xtn_h.WDATA[1]=3751060094
# UVM_INFO .\src\slave_collector.sv(28) @ 130: uvm_test_top.axi_env_h.s_collector_h[0] [slave_collector] slave_collector coverage
# UVM_INFO .\src\slave_monitor.sv(129) @ 130: uvm_test_top.axi_env_h.slave_agt_top_h[0].axi_s_agt_t_h.axi_s_mon_h [SLAVE_MONITOR_WRITE] ***SLAVE_MONITOR_WRITE***printing from slave monitor_WRITE
# axi_s_xtn_h  axi_slave_trans  -     @1357
#   AWID       integral         4     'h6
#   AWADDR     integral         32    'he9
#   AWLEN      integral         4     'h1
#   AWSIZE     integral         3     'h0
#   AWBURST    integral         2     'h0
#   WDATA[0]   integral         32    'h88d15a5d
#   WDATA[1]   integral         32    'hdf94a27e
#   WDATA[2]   integral         32    'h0
#   WDATA[3]   integral         32    'h0
#   WDATA[4]   integral         32    'h0
#   WDATA[5]   integral         32    'h0
#   WDATA[6]   integral         32    'h0
#   WDATA[7]   integral         32    'h0
#   WDATA[8]   integral         32    'h0
#   WDATA[9]   integral         32    'h0
#   WDATA[10]  integral         32    'h0
#   WDATA[11]  integral         32    'h0
#   WDATA[12]  integral         32    'h0
#   WDATA[13]  integral         32    'h0
#   WDATA[14]  integral         32    'h0
#   WDATA[15]  integral         32    'h0
#   WSTRB[0]   integral         4     'b0
#   WSTRB[1]   integral         4     'b0
#   WSTRB[2]   integral         4     'b0
#   WSTRB[3]   integral         4     'b0
#   WSTRB[4]   integral         4     'b0
#   WSTRB[5]   integral         4     'b0
#   WSTRB[6]   integral         4     'b0
#   WSTRB[7]   integral         4     'b0
#   WSTRB[8]   integral         4     'b0
#   WSTRB[9]   integral         4     'b0
#   WSTRB[10]  integral         4     'b0
#   WSTRB[11]  integral         4     'b0
#   WSTRB[12]  integral         4     'b0
#   WSTRB[13]  integral         4     'b0
#   WSTRB[14]  integral         4     'b0
#   WSTRB[15]  integral         4     'b0
#   WID        integral         4     'h6
#   ARID       integral         4     'h0
#   ARADDR     integral         32    'h0
#   ARLEN      integral         4     'h0
#   ARSIZE     integral         3     'h0
#   ARBURST    integral         2     'h0
#   RDATA[0]   integral         32    'h4
#   RDATA[1]   integral         32    'h5
#   RDATA[2]   integral         32    'h8
#   RDATA[3]   integral         32    'h7
#   RDATA[4]   integral         32    'h9
#   RDATA[5]   integral         32    'h1
#   RDATA[6]   integral         32    'h3
#   RDATA[7]   integral         32    'h2
# UVM_INFO .\src\master_monitor1.2.sv(133) @ 170: uvm_test_top.axi_env_h.master_agt_top_h[0].axi_m_agnt_h.axi_m_mon_h [MASTER_MONITOR_WRITE_CHHANLE] printing from MASTER_MONITOR_WRITE_CHHANLE
# axi_m_xtn_h  axi_master_trans  -     @1363
#   BID        integral          2     'h2
#   BRESP      integral          4     'h0
#   RDATA[0]   integral          32    'h0
#   RDATA[1]   integral          32    'h0
#   RDATA[2]   integral          32    'h0
#   RDATA[3]   integral          32    'h0
#   RDATA[4]   integral          32    'h0
#   RDATA[5]   integral          32    'h0
#   RDATA[6]   integral          32    'h0
#   RDATA[7]   integral          32    'h0
# UVM_INFO .\src\master_collector.sv(28) @ 170: uvm_test_top.axi_env_h.m_collector_h[0] [master_collector] master_collector coverage
# UVM_INFO .\src\master_monitor1.2.sv(135) @ 170: uvm_test_top.axi_env_h.master_agt_top_h[0].axi_m_agnt_h.axi_m_mon_h [MASTER_MONITOR_WRITE_CHHANLE] printing from MASTER_MONITOR_WRITE_CHHANLE
# UVM_INFO verilog_src/uvm-1.1d/src/base/uvm_objection.svh(1267) @ 670: reporter [TEST_DONE] 'run' phase is ready to proceed to the 'extract' phase
# UVM_INFO .\src\axi_SB.sv(290) @ 670: uvm_test_top.axi_env_h.axi_sb_h[0] [axi_SB]
#  Number of Read Transactions Dropped : 0
#  Number of Read Transactions compared : 0
# UVM_INFO .\src\master_driver1.sv(372) @ 670: uvm_test_top.axi_env_h.master_agt_top_h1[0].axi_m_agnt_h.axi_m_drv_h [axi_master_driver1] Report: Master_Driver_Sent 1 transactions
# UVM_INFO .\src\master_monitor1.sv(184) @ 670: uvm_test_top.axi_env_h.master_agt_top_h1[0].axi_m_agnt_h.axi_m_mon_h [axi_master_monitor1] Report: Master_Monitor_Sent 0 transactions
# UVM_INFO .\src\master_driver.sv(411) @ 670: uvm_test_top.axi_env_h.master_agt_top_h[0].axi_m_agnt_h.axi_m_drv_h [axi_master_driver] Report: Master_Driver_Sent 1 transactions
# UVM_INFO .\src\master_monitor1.2.sv(186) @ 670: uvm_test_top.axi_env_h.master_agt_top_h[0].axi_m_agnt_h.axi_m_mon_h [axi_master_monitor] Report: Master_Monitor_Sent 1 transactions
# UVM_INFO .\src\slave_driver.sv(431) @ 670: uvm_test_top.axi_env_h.slave_agt_top_h[0].axi_s_agt_t_h.axi_s_drvh_h [axi_slave_driver] Report: Slave_Driver_Sent 1 transactions
# UVM_INFO .\src\slave_monitor.sv(176) @ 670: uvm_test_top.axi_env_h.slave_agt_top_h[0].axi_s_agt_t_h.axi_s_mon_h [axi_slave_monitor] Report: slave_Monitor_Sent 1 transactions
# --- UVM Report Summary ---
# ** Report counts by severity
# UVM_INFO :   20
# UVM_WARNING :    0
# UVM_ERROR :    0
# UVM_FATAL :    0
# ** Report counts by id
# [MASTER_MONITOR_WRITE_CHHANLE]     2
# [Questa UVM]     2
# [RNTST]     1
# [SLAVE_MONITOR_WRITE]     1
# [TEST_DONE]     1
# [UVMTOP]     1
# [axi_SB]     1
# [axi_master_driver]     1
# [axi_master_driver1]     1
# [axi_master_monitor]     2
# [axi_master_monitor1]     1
# [axi_slave_driver]     1
# [axi_slave_monitor]     3
# [master_collector]     1
# [slave_collector]     1
# ** Note: $finish    : C:/questasim64_10.7c/win64/../verilog_src/uvm-1.1d/src/base/uvm_root.svh(430)
#    Time: 670 ns  Iteration: 54  Instance: /tb_top
# 1
# Break in Task uvm_pkg/uvm_root::run_test at C:/questasim64_10.7c/win64/../verilog_src/uvm-1.1d/src/base/uvm_root.svh line 430
In reply to Saqlain:
You haven’t shown any of your connections to the analysis_fifs.
Yes Dave and below is the connection made in env connect_phase
function void axi_env::connect_phase(uvm_phase phase);
    if(axi_env_cfg_h.has_scoreboard)
            foreach(master_agt_top_h[i])
                           master_agt_top_h[i].axi_m_agnt_h.axi_m_mon_h.monitor_port.connect(axi_sb_h[i].fifo_master.analysis_export);
			foreach(master_agt_top_h1[i])
                           master_agt_top_h1[i].axi_m_agnt_h.axi_m_mon_h.monitor_port.connect(axi_sb_h[i].fifo_master1.analysis_export);
            foreach(slave_agt_top_h[i])
                            slave_agt_top_h[i].axi_s_agt_t_h.axi_s_mon_h.monitor_port.connect(axi_sb_h[i].fifo_slave.analysis_export);
