Using "not" in SystemVerilog Assertions
In reply to Jung Ik Moon:
Your not property would not work either.
If you know that there will be no more than n my_seq, like no more than 10, then you can count the number of valid my_seq and use that count as an antecedent to the rest of the property. Below is the key aspect of this solution:
int my_timing= 4, count_seq;
    function void inc_count();
      count_seq=count_seq+1'b1;
    endfunction : inc_count
    // no more my_seq following.
    property my_prop_nomore;
      int t, count=0;
      @(negedge clk) disable iff (!rstn)
      count_seq <=10 |-> // If >10, then vacuity thereafter
        (my_seq, t = my_timing, inc_count() ) |->
           ##1 first_match((1, count=count+1'b1)[*0:$] ##1
                            (my_seq, inc_count())) ##0 (count >= t);
    ap_my_prop_nomore: assert property(my_prop_nomore);
Complete code
module top;
	bit clk, a, b, rstn=1'b1;
    initial forever #10 clk=!clk;
    sequence my_seq;
      ( a ##1 b);
    endsequence
    // "my_seq to my_seq delay should not be less than my_timing."
    // "my_seq to my_seq delay should     be >= than my_timing."
    property my_prop;
      int t, count=0;
      (my_seq, t = my_timing - 1) |->
      ##1 first_match((1, count=count+1'b1)[*0:$] ##1 my_seq) ##0 (count >= t);
    ap_my_prop: assert property(my_prop);
      int t, count=0;
      count_seq <=10 |->
      repeat(200) begin
        @(posedge clk);
        if (!randomize(a, b)  with
        { a dist {1'b1:=1, 1'b0:=3};
        b dist {1'b1:=1, 1'b0:=2};
    $stop;
