I have a small contrived example of using DPI-c (without UVMF) just to illustrate later what I am trying to do with UVMF. I have 5 files: one C file, two SV files, a do file and a Makefile.
The C file c.c has this simple content:
#include <stdio.h>
#include <stdlib.h>
extern void c_method() {
printf(" Hello World...!\n");
The first SV file contains a package that imports this C file, the file name is p_dpi.sv
package p_dpi;
import "DPI-C" function void c_method();
endpackage
The second SV file is the top module, top.sv:
module dpi_tb;
import p_dpi::*;
initial
$display("Before calling C Method");
p_dpi::c_method();
$display("After calling C Method");
The do file do.do is this:
set SVFLAGS "-quiet -work work -lint=full "
set PWD [pwd]
vlib work
vmap work
vlog {*}$SVFLAGS $PWD/p_dpi.sv
vlog {*}$SVFLAGS $PWD/top.sv
vlog -work work -mfcu $PWD/c.c -dpicpppath /usr/bin/gcc -ccflags "-c -Werror-implicit-function-declaration -O2"
vsim -batch -t 1ps work.dpi_tb -dpicpppath /usr/bin/gcc -voptargs=+acc
run 10 us
exit
The Makefile:
build:
@vsim -batch -do ./do.do -t 1ps -quiet -l log.log -wlfdeleteonquit
When I run “make build”, everything compiles and in simulation I see that the C file was called (see the Hello World line):
Loading sv_std.std
Loading work.p_dpi(fast)
Loading work.dpi_tb(fast)
** Note: (vsim-7082) For C/C++ auto compile, choosing compiler /usr/bin/gcc set by the -dpicpppath switch.
Loading /tmp/bmalnar@epis3dev_dpi_24737/linux_x86_64_gcc-4.8.5/vsim_auto_compile.so
Hello World...!
End time: 14:19:31 on Aug 31,2020, Elapsed time: 0:00:02
Errors: 0, Warnings: 0
As the next step, I am trying to reuse this same C file in the UVMF generator tutorial. The baseline complete solution can be run using the command: “make cli”, where cli step is defined in the Makefile as:
cli: libs build link optimize cli_run
I define my own target similar to this:
mycli: libs mydpi build link optimize cli_run
mydpi:
Here, I am re-using the do file from above, as well as the package p_dpi and the C file. The do file is:
set PWD [pwd]
vmap work
exit
To test this, I added a couple of lines in the file: project_benches/ALU/tb/testbench/hdl_top.sv
I added this import at the top:
import p_dpi::*;
And at the bottom in the initial block, I added the call to the C finction:
initial begin // tbx vif_binding_block
import uvm_pkg::uvm_config_db;
// The monitor_bfm and driver_bfm for each interface is placed into the uvm_config_db.
// They are placed into the uvm_config_db using the string names defined in the parameters package.
// The string names are passed to the agent configurations by test_top through the top level configuration.
// They are retrieved by the agents configuration class for use by the agent.
uvm_config_db #( virtual ALU_in_monitor_bfm )::set( null , UVMF_VIRTUAL_INTERFACES , ALU_in_agent_BFM , ALU_in_agent_mon_bfm );
uvm_config_db #( virtual ALU_out_monitor_bfm )::set( null , UVMF_VIRTUAL_INTERFACES , ALU_out_agent_BFM , ALU_out_agent_mon_bfm );
uvm_config_db #( virtual ALU_in_driver_bfm )::set( null , UVMF_VIRTUAL_INTERFACES , ALU_in_agent_BFM , ALU_in_agent_drv_bfm );
c_method();
When running “make mycli”, I am getting a warning and an error that says that my C function cannot be found. What should I do to fix that?
Loading /eda/mentor/2019.4/questasim/uvm-1.1d/linux_x86_64/uvm_dpi.so
** Warning: (vsim-16074) No C/C++ auto compile object files are found for the current platform ‘linux_x86_64_gcc-5.3.0’.
However some C/C++ auto compile objects are found on the following platform(s):
Please check whether you are missing the C/C++ auto compile step on the current platform.
Time: 0 ns Iteration: 0 Region: /p_dpi File: /home/bmalnar/epi/UVM_Framework/UVMF_2020.1.tar/UVMF_2020.1/docs/generator_tutorial/uvmf_template_output_dpi/project_benches/ALU/sim/p_dpi.sv
** Warning: (vsim-3770) Failed to find user specified function ‘c_method’ in DPI precompiled library search list "/eda/mentor/2019.4/questasim/uvm-1.1d/linux_x86_64/uvm_dpi.so ".
