I have a simple assertion to check clock period. The assertion fails when I add $display() in consequent. If I remove remove $display in consequent, it passes. I have used $display() in antecedents before. Can we use $display() in consequent?. Below is the code.
property clk_period ( real exp_clk_period );
time current_time;
disable iff (count>10)
(en, current_time = $time) |=> ((clk_period == ($time - current_time)), $display(“dfiff=7.2%f”, $time - current_time));//FAILS
//(en, current_time = $time) |=> ((clk_period == ($time - current_time));//PASS
endproperty : p_period
chk_clk_period: assert property(@ (posedge clk)
clk_period(exp_clk_period))
user49
April 30, 2018, 10:29pm
2
In reply to sudhirbarefoot2018 :
Rather than debugging your code, here is code that works as expected.
timeunit 1ns; timeprecision 100ps;
bit clk, en=1'b1, b;
initial forever #10 clk=!clk;
realtime exp_clk_period=20;
$timeformat(-9, 1, "ns", 8);
$display("%t", $realtime);
property p_period ( realtime exp_clk_period );
realtime current_time;
// disable iff (count>10)
(en, current_time = $realtime) |=>
(exp_clk_period == $realtime - current_time,
$display("dfiff=%t", $realtime - current_time));// OK
ap_period: assert property(@ (posedge clk) p_period(exp_clk_period));
// sim results
# 0.0ns
# dfiff= 20.0ns
# dfiff= 20.0ns
# dfiff= 20.0ns
# dfiff= 20.0ns
See Paper: VF Horizons:PAPER: SVA Alternative for Complex Assertions | Verification Academy
