Using automatic variables inside a fork - join_none
Hi:
How do I re-write the code shown below, using a for loop and automatic variables?
Thank You!
task class_c::clear();
         forever begin
            @(this.incoming[0]);
            if (this.incoming[0] == 1) begin
               #5ns;
               this.incoming[0] = 0;
         forever begin
            @(this.incoming[1]);
            if (this.incoming[1] == 1) begin
               #5ns;
               this.incoming[1] = 0;
         forever begin
            @(this.incoming[2]);
            if (this.incoming[2] == 1) begin
               #5ns;
               this.incoming[2] = 0;
         forever begin
            @(this.incoming[3]);
            if (this.incoming[3] == 1) begin
               #5ns;
               this.incoming[3] = 0;
         forever begin
            @(this.incoming[4]);
            if (this.incoming[4] == 1) begin
               #5ns;
               this.incoming[4] = 0;
         forever begin
            @(this.incoming[5]);
            if (this.incoming[5] == 1) begin
               #5ns;
               this.incoming[5] = 0;
         forever begin
            @(this.incoming[6]);
            if (this.incoming[6] == 1) begin
               #5ns;
               this.incoming[6] = 0;
         forever begin
            @(this.incoming[7]);
            if (this.incoming[7] == 1) begin
               #5ns;
               this.incoming[7] = 0;
         forever begin
            @(this.incoming[8]);
            if (this.incoming[8] == 1) begin
               #5ns;
               this.incoming[8] = 0;
         forever begin
            @(this.incoming[9]);
            if (this.incoming[9] == 1) begin
               #5ns;
               this.incoming[9] = 0;
         forever begin
            @(this.incoming[10]);
            if (this.incoming[10] == 1) begin
               #5ns;
               this.incoming[10] = 0;
         forever begin
            @(this.incoming[11]);
            if (this.incoming[11] == 1) begin
               #5ns;
               this.incoming[11] = 0;
         forever begin
            @(this.incoming[12]);
            if (this.incoming[12] == 1) begin
               #5ns;
               this.incoming[12] = 0;
         forever begin
            @(this.incoming[13]);
            if (this.incoming[13] == 1) begin
               #5ns;
               this.incoming[13] = 0;
         forever begin
            @(this.incoming[14]);
            if (this.incoming[14] == 1) begin
               #5ns;
               this.incoming[14] = 0;
         forever begin
            @(this.incoming[15]);
            if (this.incoming[15] == 1) begin
               #5ns;
               this.incoming[15] = 0;
         forever begin
            @(this.incoming[16]);
            if (this.incoming[16] == 1) begin
               #5ns;
               this.incoming[16] = 0;
         forever begin
            @(this.incoming[17]);
            if (this.incoming[17] == 1) begin
               #5ns;
               this.incoming[17] = 0;
   join_none
endtask: clear
In reply to new_to_uvm:
I wish to do something similar with this code.
Thank You!
task class_c::start_something ();
      forever begin
         @some_event;
               if (this.pi[0] == 1)  start_operation [0] = 1;
               if (this.pi[1] == 1)  start_operation [1] = 1;
               if (this.pi[2] == 1)  start_operation [2] = 1;
               if (this.pi[3] == 1)  start_operation [3] = 1;
               if (this.pi[4] == 1)  start_operation [4] = 1;
               if (this.pi[5] == 1)  start_operation [5] = 1;
               if (this.pi[6] == 1)  start_operation [6] = 1;
               if (this.pi[7] == 1)  start_operation [7] = 1;
               if (this.pi[8] == 1)  start_operation [8] = 1;
               if (this.pi[9] == 1)  start_operation [9] = 1;
               if (this.pi[10] == 1) start_operation [10] = 1;
               if (this.pi[11] == 1) start_operation [11] = 1;
               if (this.pi[12] == 1) start_operation [12] = 1;
               if (this.pi[13] == 1) start_operation [13] = 1;
               if (this.pi[14] == 1) start_operation [14] = 1;
               if (this.pi[15] == 1) start_operation [15] = 1;
               if (this.pi[16] == 1) start_operation [16] = 1;
               if (this.pi[17] == 1) start_operation [17] = 1;
         join_none
endtask: start_something
In reply to your first post new_to_uvm:
   foreach(incoming[i])
         fork : foreach_loop
           int j = i;
             wait (incoming[j] == 1);
             #5ns;
             incoming[j] = 0;
          join_none : foreach_loop
   wait(0); // your posted code never exits; not sure if that's what you want
In reply to your second post new_to_uvm:
There is no need to use a fork statement unless you have a time consuming process to fork. Your posted code would simply be
     forever  @some_event foreach(pi[i]) start_operation [i] = 1;
Thank You Dave!
Thank You Dave!
Yes, I wanted the forever begin in there.
