Using and / or operator within Multi -clocked Sequence
Hi Ben ,
(1) I am intrigued by the concept of leading clock in a multi clocked sequence and seek your assistance for the same .
Here’s what I have noted via various trial and error :
The and, or sequence operators require that both sequence start at the same time
 Generally when we write :
      assert  property ( @( posedge clk ) B  and  C ) ;
Here both B and C are evaluated on each posedge of clk i.e both sequence start at the same time i.e on posedge of clk
  Whereas  in  the  top  multi clocked  sequence :
      assert  property (  @(posedge clk1) B and @(posedge clk2) C ) ;
Here there exists ambiguity whether the variables B and C start evaluation on posedge of clk1 OR at posedge of clk2
  **i.e sequence don't necessarily start at the same time**
   On  changing  code  to :
       ap1:assert property ( @(posedge clk0)  A  |=>  mclocks ) ;
   Now variables B and C start at the same time i.e subsequent posedge of clk1 and clk2 respectively **after the antecedent is True on leading clock ( clk0 )**
(2) When trying the following :
      ap2:assert property ( @(posedge clk0) mclocks );
      ap3:assert property ( @(posedge clk1) mclocks );
      ap4:assert property ( @(posedge clk2) mclocks );
  I still observe Compilation Error  : [edalink](https://www.edaplayground.com/x/Vnr9)
  I believe this is due to the clk0 / clk1 / clk2 ( mentioned in the assert property ) getting overridden by clk1 for B and clk2 for C ( within the sequence ) .
  So the equivalent expression remains the same :
       ap2:assert property ( mclocks );
       ap3:assert property ( mclocks );
       ap4:assert property ( mclocks );
