I have a piece of code like below. but it failed at syntax error. any help is appreciate.
bit clk;
clk = 0;
forever begin
#(10.0ns) clk = ~clk;
function realtime gen_rand_delay();
int t = {$random()} % 6;
realtime dly;
case (t)
0 : begin
dly = 0.0ns;
1 : begin
dly = 1.0ns;
2 : begin
dly = 2.0ns;
3 : begin
dly = 3.0ns;
4 : begin
dly = 4.0ns;
5 : begin
dly = 5.0ns;
endcase
return dly;
endfunction : gen_rand_delay
assign my_clk = #(gen_rand_delay()) clk;
In reply to zz8318:
the following worked for me. I provide 3 versions for the delays and the assign.
The use of the randomize gives you more options.
timeunit 1ns/100ps;
`include "uvm_macros.svh"
import uvm_pkg::*;
bit clk, a, b, my_clk, my_ck2;
int v, v2, v3;
clk = 0;
forever begin
v=gen_rand_delay();
v2=gen_rand_delay2();
v3=gen_rand_delay3();
function realtime gen_rand_delay2(); // <--- UPDATED
automatic int t = {$random()} % 6;
//realtime fly; // CORRECTION
/*case (t)
0 : begin
dly = 0.0ns;
1 : begin
dly = 1.0ns;
2 : begin
dly = 2.0ns;
3 : begin
dly = 3.0ns;
4 : begin
dly = 4.0ns;
5 : begin
dly = 5.0ns;
endcase */
return t * 1ns; // CORRECTION
endfunction : gen_rand_delay2
realtime dly;
/*case (t)
0 : begin
dly = 0.0ns;
1 : begin
dly = 1.0ns;
2 : begin
dly = 2.0ns;
3 : begin
dly = 3.0ns;
4 : begin
dly = 4.0ns;
5 : begin
dly = 5.0ns;
endcase */
return dly * 1ns;
function realtime gen_rand_delay3();
int t;
realtime dly;
if (!randomize(t) with
{ {t>0};
{t<=5};
//{ a dist {1'b1:=1, 1'b0:=1};
// b dist {1'b1:=1, 1'b0:=2};
) `uvm_error("MYERR", "This is a randomize error");
return dly * 1ns;
endfunction : gen_rand_delay3
//assign #gen_rand_delay() my_clk = clk;
assign #v my_clk = clk;
assign #v2 my_clk2 = clk;
assign #v3 my_clk3 = clk;
repeat(200) begin
@(posedge clk);
if (!randomize(a, b) with
}) `uvm_error("MYERR", "This is a randomize error");
$finish;
- SVA Handbook 4th Edition, 2016 ISBN 978-1518681448
- A Pragmatic Approach to VMM Adoption 2006 ISBN 0-9705394-9-5
- Using PSL/SUGAR for Formal and Dynamic Verification 2nd Edition, 2004, ISBN 0-9705394-6-0
- Real Chip Design and Verification Using Verilog and VHDL, 2002 isbn 978-1539769712
- Component Design by Example ", 2001 ISBN 0-9705394-0-1
- VHDL Coding Styles and Methodologies, 2nd Edition, 1999 ISBN 0-7923-8474-1
- VHDL Answers to Frequently Asked Questions, 2nd Edition ISBN 0-7923-8115
- SVA Alternative for Complex Assertions
Verification Horizons - March 2018 Issue | Verification Academy
- SVA: Package for dynamic and range delays and repeats | Verification Academy
- SVA in a UVM Class-based Environment
- FREE BOOK: Component Design by Example … A Step-by-Step Process Using VHDL with UART as Vehicle | Verification Academy
In reply to zz8318:
Let me add to Ben’s explanation on what the original problems with your code were.
- You had the delay in the wrong spot for the continuous assign statement.
- You had an illegal variable declaration for t inside function gen_rand_delay(). You need to do something different if you want a new value for t every time the function gets called. See this.
- You also need to be more specific about when or if you want a new delay calculated.
