It is difficult to provide an answer without seeing the source code you are describing. If you can post the code in question, perhaps a more definitive answer can be given.
In reply to sachins:
class mem_ctl_checker;
mailbox#(mem_xactn) in_box;
mem_xactn cur_xactn,mem_q[$],found_xactn_q[$];
int num_dut_err, found_ind_q[$];
function new( mailbox#(mem_xactn) new_mbox);
this.in_box=new_mbox;
virtual task main;
forever begin :loop
in_box.get(cur_xactn);
if(cur_xactn.kind==RST) begin: clrmem
mem_q.delete();
end: clrmem
if(cur_xactn.kind==WR) begin: wrmem
found_ind_q=mem_q.find_first_index with(cur_xactn.addr==item.addr);
if(found_ind_q.size!=0) begin: indeq
mem_q[found_ind_q[0]].data_in=cur_xactn.data_in;
end: indeq
else begin: notmatch
mem_q.push_back(cur_xactn);
end: notmatch
end:wrmem
Here is the transaction class
class mem_xactn;
rand logic [DATA_WIDTH-1:0] data_in;
logic [DATA_WIDTH-1:0] rd_data;
rand logic [ADDR_WIDTH-1:0] addr;
rand bit [3:0] no_of_rst;
rand mem_op kind;
virtual function string show_as_string ();
if(kind == WR)
show_as_string = $psprintf ("%s KIND: %s ADDR: %0d DATA %0d",`CVC_PREFIX,kind.name, addr, data_in);
if(kind == RD)
show_as_string = $psprintf ("%s KIND: %s ADDR: %0d",`CVC_PREFIX,kind.name, addr);
if(kind == RST)
show_as_string = $psprintf ("%s KIND: %s", `CVC_PREFIX,kind.name);
endfunction : show_as_string
endclass : mem_xactn
If you look at the line found_ind_q=mem_q.find_first_index with(cur_xactn.addr==item.addr); the intent here is to find the item’s index that matches the current address. This is the inbuilt way of searching items (with various attributes like first index) in the queue. Hope this answers your question…
