Hi
I have a virtual class Transaction like this
virtual class Transaction #(int width=100, height=50);
methods and constraints
and then i create some transaction types
typedef Transaction #() Transactionx
My question Is it a good pratcice to use this typedef as a parameter in my class i.e
class transactor #(int , int , type T= Transactionx)
And then use this class as a base class to be instantiated in other classes What are the shortcomings of this or any better alternative any one can suggest
In reply to arjumand:
A couple of issues with your question:
Creating a specialization of a parameterized virtual(abstract) class does not make it a non-virtual(concrete) class. You still need to extend it into a concrete class before constructing as an object.
class TransX extends Transaction#(100,50);
class TransY extends Transaction#(100,100);
These are now two concrete classes. However, they do not share the same common base class. If you want them to share a common base class, they need to be extended from the same unparameterized class, or the same specialization of a parameterized class.
Finally, specializing a class with a type that is an extension of another type does not make the two specializations an extension of each other. For example
class A;
class B extends A;
class xactor#(type T);
xactor#(A) xa_h;
xactor#(B) xb_h;
xb_h = new;
xa_h = ab_h; // not legal
xa_h and xb_h are two unique specializations and the fact that B is an extension of A is irrelevant.
Without knowing more about what you are trying to accomplish, its hard to know if any of this is relevant to you, or suggest a better alternative.
Hello Dave thankds for your reply
Absolutely i know this as you wrote above
My core question was just to ask that i have to use a BFM from someone else which is built like that as i wrote above in my question.. i.e A virtual class with some methods and constraints . Typedef the Transaction class to have a say Transactionx and use this as a parameter in normal class.
The author call this class a base class constructed in a class called BFM.
class A;
class B extends A;
xactor#(A) xa_h;
xactor#(B) xb_h;
xb_h = new;
Without know more about what you are trying to accomplish, its hard to know if any of this is relevant to you, or suggest a better alternative.
Your question seems to be just “is it OK to pass a virtual class as a type parameter T to another class”
The answer is yes, as long as T is only used for things that would be OK for a virtual class type. (i.e. you are not going to have
T handle = new; // this would not be OK if T were not a class, or a virtual class
