Hi All,
consider an uvm_sequence code
class my_seq extends uvm_sequence #(packet);
`uvm_object…
function new…
virtual task body();
packet transaction;
for (int i=0; i<3; i++)begin
`uvm_do(transaction)
transaction.last_item=1;
`uvm_send(transaction)
I do understand the difference between uvm_do and
uvm_send
But, here I would like to understand the significance of those two.
For 3 transactions, `uvm_do has been used; means, three times a transaction will be created and randomized.
For the 4th transaction, `uvm_send has been used; means last transaction, no randomization, it should have the previous randomized value.
Can I say this?
" the combinations of uvm_do and
uvm_send will be used if two consecutive transactions wants to have the same value"
Kindly share your opinion on this.
Thank You,
