sir, I’m getting an error as “Usage of ‘slv_if.slv_cb_drv’ inconsistent with ‘clocking block’ object”,
what can I rectify it?
This is the interface file
In this below task from slave monitor I’m getting error in line 47 and also in all lines like 49,51,54, etc where I’ve DECLARED clk delay using interface clocking delay
First of all, thanks for your reply, sir.
sorry sir, the error is from slave driver not from slave monitor, my mistake,
//The interface file is correct which I’ve declared at the beginning.
//This is the slave monitor code, please look into it, line number 47,49,52, etc. are errors
class router_slave_driver extends uvm_driver #(read_xtn);
`uvm_component_utils(router_slave_driver)
virtual router_if.SLV_DRV slv_if;
router_slave_agent_config slv_agt_cfg;
extern function new(string name="router_slave_driver",uvm_component parent);
extern function void build_phase(uvm_phase phase);
extern function void connect_phase(uvm_phase phase);
extern task run_phase(uvm_phase phase);
extern task send_to_dut(read_xtn xtn);
extern function void report_phase(uvm_phase phase);
function router_slave_driver::new(string name="router_slave_driver",uvm_component parent);
super.new(name,parent);
function void router_slave_driver::build_phase(uvm_phase phase);
if(!uvm_config_db #(router_slave_agent_config)::get(this,"","router_slave_agent_config",slv_agt_cfg))
`uvm_fatal("router_slave_driver","unable to get the slv_agt_top,have you set it?")
super.build_phase(phase);
function void router_slave_driver::connect_phase(uvm_phase phase);
slv_if=slv_agt_cfg.slv_if;
super.connect_phase(phase);
task router_slave_driver::run_phase(uvm_phase phase);
forever begin
req=read_xtn::type_id::create("req");
send_to_dut(req);
seq_item_port.item_done();
task router_slave_driver::send_to_dut(read_xtn xtn);
xtn=read_xtn::type_id::create("xtn");
@(slv_if.slv_cb_drv);//line 47
while(slv_if.slv_cb_drv.valid_out!==1'b0)
@(slv_if.slv_cb_drv);//49
repeat(xtn.no_of_cycles)
@(slv_if.slv_cb_drv);//52
slv_if.slv_cb_drv.read_enb<=1'b1;
wait(!slv_if.slv_cb_drv.valid_out)
while(slv_if.slv_cb_drv)
slv_if.slv_cb_drv.read_enb<=1'b0;
//slv_agt_cfg.drv_data_count++;
`uvm_info("Router_slv_driver",$sformatf("printing from driver\n%s",xtn.sprint()),UVM_LOW)
function void router_slave_driver::report_phase(uvm_phase phase);
//`uvm_info(get_type_name(),$sformatf("Report:router read driver sent %0d transactions",slv_agt_cfg.drv_data_count),UVM_LOW)
super.report_phase(phase);
//this is slave agt config code
class router_slave_agent_config extends uvm_object;
`uvm_object_utils(router_slave_agent_config)
virtual router_if slv_if;
uvm_active_passive_enum is_active=UVM_ACTIVE;
extern function new(string name="router_slave_agent_config");
function router_slave_agent_config::new(string name="router_slave_agent_config");
super.new(name);
Is this information enough for you sir to debug this?
