Hi all,
I have a question regarding the usage of DPI-C in the C-programming environment.
The problem I’m having a compiling issue where upon gcc compile, I get the following message in my terminal:
In file included from mytest.c:2:0:
vc_hdrs.h:9:19: fatal error: svdpi.h: No such file or directory
#include <svdpi.h>
compilation terminated.
The following are the lines of code that I am using:
testbench.sv
module test;
export "DPI-C" function printf_output; // sending the string_output task to c
function void printf_output();
$display("Hello from SV");
This is the c programming file that I am using to import the SystemVerilog functions: mytest.c
#include <stdio.h>
#include "vc_hdrs.h"
extern void printf_output();
int main() {
printf("THIS IS THE C ENVIRONMENT");
printf_output();
return 1;
When I compiled my SystemVerilog file with VCS, it generated a header file: vc_hdrs.h
#ifndef _VC_HDRS_H
#define _VC_HDRS_H
#ifndef _GNU_SOURCE
#define _GNU_SOURCE
#endif
#include <stdio.h>
#include <dlfcn.h>
#include <svdpi.h>
#ifdef __cplusplus
extern "C" {
#endif
#ifndef _VC_TYPES_
#define _VC_TYPES_
/* common definitions shared with DirectC.h */
typedef unsigned int U;
typedef unsigned char UB;
typedef unsigned char scalar;
typedef struct { U c; U d;} vec32;
#define scalar_0 0
#define scalar_1 1
#define scalar_z 2
#define scalar_x 3
extern long long int ConvUP2LLI(U* a);
extern void ConvLLI2UP(long long int a1, U* a2);
extern long long int GetLLIresult();
extern void StoreLLIresult(const unsigned int* data);
typedef struct VeriC_Descriptor *vc_handle;
#ifndef SV_3_COMPATIBILITY
#define SV_STRING const char*
#else
#define SV_STRING char*
#endif
#endif /* _VC_TYPES_ */
#ifdef __cplusplus
#endif
#endif //#ifndef _VC_HDRS_H
Is there something I have to change in the lines of my code to resolve this fatal error issue upon gcc compile on the c files? Any help would be appreciated.
Thanks!
Sangwoo Kim
