Usage of create method of uvm_factory over new
It is advised that “create” method of uvm_factory should be used while creating child components in build_phase. Here we are not defining or overriding create method.
Also we do define a constructor for each component.
So is it really necessary to define a constructor if we are going to use create method?
Dipali
But you are defining a create method because of the `uvm_component_utils macros. See a little of what that does in this post. The create method will eventually call the constructor that you need to define inside your component.
Dave
Thanks Dave!
It’s clear now.
