I just noticed something interesting regarding $urandom_range. When using a type of 4b or smaller for specifying the max value $urandom_range will always return 0. $urandom_range works as expected when using a type > 4b for the max value.
Consider the following example. I have a VHDL package where I’ve defined a number of constants:
subtype test5_t is unsigned(4 downto 0);
constant TEST5_MAX : test5_t := "11111";
subtype test4_t is unsigned(3 downto 0);
constant TEST4_MAX : test4_t := "1111";
I noticed that when using a type smaller than 4b for calling $urandom_range I always get a zero output:
int test5 = $urandom_range(0, test_custom_pkg::test5_max);
int test4 = $urandom_range(0, test_custom_pkg::test4_max);
$info("UT: test5_max=%0d, test5=%0d", test_custom_pkg::test5_max, test5);
$info("UT: test4_max=%0d, test4=%0d", test_custom_pkg::test4_max, test4);
Output:
# ** Info: UT: swap test5_max=31, test5=15
# ** Info: UT: swap test4_max=15, test4=0 // This is wrong. It always returns 0
Is this expected? The SV LRM states that urandom_range should be called with a unsigned int so you could argue that this is undefined behavior. Still this is quite unexpected.
I have tested this on Questa 2019.4_2. Any input is appreciated.
