Hi.
I have encountered an issue that puzzles me when using ‘assert’, specifically when trying to assert the value of of a flip-flop after the sampling edge (rising edge in my case). If I place an ‘always’ block that prints all the changes on a flip-flop output I can see that at the rising edge it equals the expected value. However if I try to ‘assert’ the value at the same moment in time, the assert ‘thinks’ that flip flop did not yet sample, only a a moment later (that can be arbitrarily small). ‘if’ behave like ‘assert’ (trying to compare to the expected value at that moment). Below is my sample code, and attached an image showing the contradiction between the assert and the prints. I am using Modelsim as simulator. Thanks.
`timescale 1ns/1ns
module example_t(input logic clk, input logic resetb, input logic selector, output logic result);
always_ff @ (posedge clk or ~resetb)
if(~resetb)
result <= 0;
result <= selector ? 1'b1 : 1'b0;
module tst();
logic clk;
logic resetb;
logic selector;
logic result;
example_t example(.clk(clk), .resetb(resetb), .selector(selector), .result(result));
//Simulate a clock
always
#10 clk = ~clk;
initial
clk = 0;
resetb = 0; //Reset
selector = 0;
#20
@(posedge clk);
resetb = 1;
#20
@(posedge clk);
selector = 1;
#20 //Clock cycle
@(posedge clk);
assert(result == 1'b1); _**//this fails at 70ns, meaning that result != 1**_
always @ (result)
$display("result=%h time=%t",result, $realtime); _**//This will print that result ==1 at 70ns**_
