Could anyone help me understand why the following code has a bug?
class foo
rand byte bar;
constraint c_bar_dist{
bar dist {[0:99] := 5, 100 := 95};
class foo
rand byte bar;
What error are you getting?
If you add a semi-colon after āclass fooā, your code works fine.
Thank you for your response. I just came across a post on LinkedIn that said that this code has a logical bug (rather than a syntax error), wherein the probabilities exceed 100. And I couldnāt understand why. Thatās what I was seeking an explanation for. Sorry for not clarifying this earlier.
āBugsā only exist when there is a difference in actual versus expected/required behavior. You never mentioned what you are expecting.
I can assume you were expecting a distribution with the value 100 occurring 95% of the time, and the other values in the range 0-99 occurring 5% of the time. If that is the case, you needed to specify the weight using [0:99]:/5
not [0:99]:=5
With [0:99]:=5
, a weight of 5 gets placed on each value so the total of all the weights is 595. Then the probability of the value 100 is 95/(500+95)=16%.
With [0:99]:/5
, the weight of 5 get applied to the range as a whole. Then the probability of the value 100 is 95/(5+95)=95%.
Note the IEEE 1800-2023 SystemVerilog LRM has clarified the description of the :/
weight calculation showing the weight applies to the range as a whole, not divided into each value in the range.
Thanks a lot for the clarification. That is what I was expecting.
