Unable to use randc for uniqueness
I’m trying to solve Einstein’s riddle using system verilog constraints
Here I see that all the constraints I have written in einsten_constraints & einsten_constraint_problem are being followed but randc declaration in einsten_constraints isn’t being followed its repeating because only member elements are treated as randc.
typedef enum int { red,	green,	white, 	yellow, blue } 	color_e;
class einsten_constraints;
  randc color_e color;
  constraint c1 ..
  function void display();
class einsten_constraint_problem;
   rand einsten_constraints ex[5];
   function new();
  constraint c4 { foreach(ex[i])
    				if(i>0)
    					(ex[i].color == color_e'(white)) <-> (ex[i-1].color == color_e'(green));
program automatic top;
  einsten_constraint_problem ex_super;
  initial
      ex_super = new();
      if(ex_super.randomize())
              $display("randomization succesful");
endprogram
If i try to use below code in einsten_constraint_problem then its randomizing second time & constraints declared in einsten_constraint_problem wont be followed.
If i dont want to use 2 foreach loops and check all possible ways for uniqueness, is there a way to solve this using randc
  function void pre_randomize();
    foreach(ex[i])
        if(!(ex_c.randomize()))
        	ex[i] = ex_c ;
In reply to GanBa:
randc does not guarantee uniqueness across multiple array elements. It only ensures that in successive randomizations, a different solution is provided until all possible solutions are exhausted. You only call randomize() once.
You might want to read Redirecting…
In reply to GanBa:
Got it. Thank you Dave.
