Un-named procedural blocks in Verilog-2001 can't declare local variable
Hello Dave,
I have one query related to “Local variable declarations inside an unnamed block”.
As per Verilog LRM,local variables can only be declared inside a named block only as shown below :
initial
begin:B1
integer i;
i = 5;
If we remove the name of the block,Xilinx throws a compilation error as “Declarations not allowed in unnamed block”.
But we have found that simulators like Riviera-pro,VCS,NCSIM supports the local declarations with-out naming the block . The below code could be executed in EDA playground with all the 3 simulators selected at least once without any compilation error .
initial
integer i=5;
Could you please make it clear how this is allowed in the above 3 simulators ?
Susmita
In reply to sush:
This Mentor forum is not for tool specific support, but I believe EDAplayground is set up to treat all source code as SystemVerilog by default. If you try the other simulators that do not support SystemVerilog, you will get an error.
