I have a parameterized driver. Direct usage make the code verbose.
So, I am trying to make typedefs for these components.
For example, one line of the code appears like this in my agent class:
typedef av_st_mst_driver #(AV_WIDTH) av_st_mst_driver_t;
Please note that the parameter AV_WIDTH is within the scope of the agent class where the above line is defined.
However, when I try to put the typedef in a common package, I get an error.
The error is pointing to #(AV_WDITH). Is this because value of AV_WIDTH is being resolved in the packet?
When I put this in the agent class, I see no issue.
Is there a solution to this in case I want to put these typedefs in a common package so that multiple agents can use these typedefs?
In reply to verif_learner:
The key question you do not answer: where is the parameter AV_WIDTH defined?
This parameter has to have a specific value for the typedef when declaring this in your package.
chr_sue,
The parameter is a part of agent class definition. Like below:
class av_st_mst_agent #(AV_WIDTH) extends uvm_agent;
I know that you are going to say that AV_WIDTH has to be within package scope but having a global parameter defeats the purpose of what I am trying to do here.
The agent is parameterized and hence I can fix its value when I create it later.
I have other agents like this and they all have same parameter name – AV_WIDTH
So, if I fix value of AV_DWIDTH in the package scope then I no longer have different values for different agents or 2 different agent instance of the same agent.
Right now, I have put typedef in the class itself but this way I have to repeat typedefines at multiple places
The question is not what is legal and can be compiled. The question is what is useful.
To avoid dealing with parameterized classes we can define a typedef for a specific parameter. This is a useful application.
The most often used typedef is for a sequencer like this
typedf uvm_sequencer #(my_seq_item) my_sequencer.
If you have more than 1 sequncer in your environment you have to do this for every seq_item you are using.
