Type used in parameterized class using it as argument to new constructor
I want to use type T used in parameterized class in overriding new constructor argument. I am getting given error.
Ex. parameterized class
class packet #(type T = int);
T address;
T data ;
Ex. new constructor argument
function new(string name = “wr_rd_sequence”, type T = int);
super.new(name);
Error-[SE] Syntax error
“mem_sequence.sv”, 114: token is ‘T’
In reply to DhavalP:
If the uvm_object class is registered with the factory the format of the constructor is restricted to 1 argument, the name of string type:
function new(string name = "");
  super.new(name);
If you are using a parameterized class thios does not have any influence on the constructor.
I want to remove parameterized class and use constructor overriding instead.
You do not have to do that. But it should look like this:
class my_item #(type T = int) extends uvm_sequence_item;
   T my_var;
      super.new(name);
Or you have the parameter in a pkg.
You cannot pass a type as an argument to a function/method. You cannot use a type as a value that you use in any kind of assignment. Types can be overriden as parameters at compilation as class specialization; you cannot do this procedurally in simulation. However, it is possible to choose between constructing different specializations using the UVM factory or other similar patterns.
But this is a classic XY Problem. We do not know what known problem led you to think of passing a type as a constructor argument as a possible solution…
I wanted to pass parameters as variables instead constants so it is not possible using parameterized class and I led to take it as overriding new constructor.
I have same no. of arguments in create as new constructor but still I am getting elab error.
Am I missing something?
function new(string n=“class_new”, int const_d=4, int const_e=4, int T=4);
obj_new[str_name] = class_new::type_id::create(str_name, D, E, tmp_type);
-I-:
-I-:Error-[TMAFTC] Too many arguments to function/task call
-I-:“uvm_object_registry::create(str_name, D, E, tmp_type)”
-I-: The above function/task call is done with more arguments than needed.
-I-:
You missed the mention that you can’t change the number of constructor arguments for classes registered with the UVM factory. You can make assignments to the object right after construction.
We still do not know what known problem led you to think of passing a type as a constructor argument as a possible solution.
