What is type of unsigned int, is it packed or unpacked?
And How can I write it in terms of bits if I want to do a type cast ?
Regards,
Regards,
In reply to papatel:
You can turn any data type into a named typedef, then use it in a cast.
typedef int unsigned uint;
uint'(A+B)
Any integral data type is packed. The above type is equivalent to declaring
typedef bit [31:0] uint;
Thank You so much Dave!! But Unsigned int size will be 64 bit isn’t ? Please correct me if I am wrong. The equivalent will be typedef bit[63:0] uint ?
Regards,
Incorrect. SystemVerilog fixed the size of int to be 32-bits when 64 bit systems were not as popular as they are today.
Thank You For the Information Dave. That helps!!
Regards
