In my environment, I have a host agent and a driver that should access to two different interfaces of DUT (TX and RX).
I have sequences for TX transactions and RX transactions called from a test in fork join
tx_seq(0
rx_seq()
join
However the driver completes one transaction (either TX or RX) and then only start the next transaction since the driver is coded already like this,
forever begin
seq_item_port.get_next_item(item);
case(item.req_type)
TX: tx_dr();
RX: rx_dr()
endcase
seq_item_port.item_done();
end //
I want to change this to do a parallel fullduplex transaction (TX and RX driving out parallely). Is this possible given that I have the agent with single sequencer?
Please give some suggestions on how I can build a driver that can cater to this with a singe agent.
One way to do this as follows;
→ Your TX and RX sequences must share a common sequence item or transaction.
→ Define an enum variable in a package like; typedef enum bit [1:0] {TX,RX,FULL_DUPLEX} op_type;
→ Set the enum variable inside build_phase of testcase using set_config_int(“*”,“op_t”,2); OR you can set globally.
→ Similar like in testcase fork…join; apply the same inside the driver like;
drive_dut(); //Task calling which has driving to DUT logic
→ Define the task drive_dut inside the driver like;
task drive_dut();
if(op_t == FULL_DUPLEX) begin //op_t is enum declaration
tx_dr();
rx_dr();
join
Since you said full duplex I understand that the Tx and Rx transactions will happen simataneously.
For your requirement you can use seq_item_port.peek to identify the current data item type on the sequencer fifo and then if it matches with the required type emit the item_done.
May be the following code will help,
class my_data_item extends uvm_sequence_item;
//Common fields if any b/w tx and rx
endclass : my_data_item
class my_tx_item extends my_data_item;
// Fields for the Tx Item
endclass : my_tx_item
class my_rx_item extends my_data_item;
// Fields for the Rx Item
endclass : my_rx_item
class my_driver extends uvm_driver#(my_data_item);
my_tx_item tx_q[$];
my_rx_item rx_q[$];
get_item();
tx_drv();
rx_drv();
join
endtask : run_phase
virtual task get_item();
my_data_item item;
forever begin
if(tx_q.size()==0) begin // Fetch item only if we dont have one in our local queue
seq_item_port.peek(item);
if(item.get_type_name()=="my_tx_item") begin
my_tx_item tx_item;
$cast(tx_item,item);
tx_q.push_back(tx_item);
if(rx_q.size()==0) begin
if(item.get_type_name()=="my_rx_item") begin
my_rx_item rx_item;
$cast(rx_item,item);
rx_q.push_back(rx_item);
#1; // This is must to avoid dead lock
end // End: forever
endtask : get_item
virtual task tx_drv();
while(1) begin
if(tx_q.size()!=0) begin
my_tx_item tx_item;
tx_item = tx_q.pop_front();
// Implement Tx Driving part here
endtask : tx_drv
virtual task rx_drv();
while(1) begin
if(rx_q.size()!=0) begin
my_rx_item rx_item;
rx_item = rx_q.pop_front();
// Implement Rx Driving part here
endtask : rx_drv
#1 is never required.
But you have to make sure you are doing first get_item and then run in parallel tx_drive and rx_drive. Your fork/join does not guarantee get_item is executed first. What the first task is is randomly selected (but repeatable).
