My reference model ref_model.svh class, extends uvm_component. For each 1x incoming stimulus received at the ref_model I have to generate 10x output stimulus and send them to the scoreboard.
My problem :
The transactions @ref_model are printed correctly, that means i get all tran Nr.0 down to tran Nr.9 logged. But at the @scoreboard, I get the 10x transactions but the transaction is allways the last transaction, i.e. tran Nr.9.
Without seeing any code, it can be difficult to provide a definitive solution.
Do you clone() your transactions when you send them to the scoreboard? If you re-use transaction handles, then you will be queuing the single handle, resulting in all transactions being the same.
Refer to the UVM Cookbook section on UVM Monitors for more information.
